fuel filter
fuel filter
Old 03-23-2009, 10:40 AM
Pete737
Pete737's Avatar
Default fuel filter
I have a moderate to heavy leak on my fuel filter guys. Is their any type of filter I could pick up locally that would work? Could I use a sullivan crap trap? BTW my leaky filter is a canister type about 1" long and 5/8" in diameter.
Thanks! Pete
Old 03-23-2009, 10:44 AM
KC36330
Default RE: fuel filter
the crap trap is too course a mesh, the filter is mostly to catch the particles off the fuel pump as it wears to prevent them entering the fuel solenoid. if you can find a paper type filter at your local car parts place with the right size for your application they'll work just fine.
Old 03-23-2009, 11:55 AM
joeflyer
My Feedback: (48)
I've used the Dubro Final filter on several of my turbines. I works well and most hobby shops stock them. The 4 mm. line is a tight fit over the nipple so you might have to work at it a bit.
http://www3.towerhobbies.com/cgi-bin...?&I=LXD742&P=7
Joe
Old 03-23-2009, 12:01 PM
Pete737
Pete737's Avatar
Thanks guys!
Pete
Old 03-23-2009, 12:09 PM
Gordon Mc
I've used the Hangar 9 metal fuel filter almost exclusively, for many years. Never had a problem with one.
Only 'issue' is that the large nipple does require a bit more patience in getting the plumbing done initially, but that's no big deal.
Gordon
Old 03-23-2009, 01:54 PM
KC36330
if you'll swipe a flame over your tubing, and i do mean swipe, don't linger, it'll slip right over the fittings.
Old 03-23-2009, 02:48 PM
highhorse
highhorse's Avatar
ORIGINAL: KC36330
A heat gun will work too, but fire is more fun than a fancy hair dryer.
