Receiver packs
Receiver packs
How long does a 4000 mah receiver pack last and how long will it take to be charged by a charger with a charge current of .1 to 5 amps?
1 Post
RE: Receiver packs
How long it'll last depends entirely on what you're using it for - high torque servos for example will drain the pack much faster than regular ones.
Charge time = capacity / charge rate
...so 40 hours at .1A, 48 mins at 5A.
RE: Receiver packs
Wow Only 48 minutes? I was expecting hours. Right now I am using a Hitec HS-985MG which has 172.2 ounces of torque and a Futaba S3003. I don't know how much torque the S3003 has.
RE: Receiver packs
the cells could overheat and vent, whch would ruin them. I think you would be ok charging a 4000mah pack at 5 amps, but I would recomend doing it at 4 amps.
RE: Receiver packs
Refresh my memory. We used to bypass the main batt pack and put in a receiver pack so that all the voltage in main went to the motor. How is it done?
RE: Receiver packs
ORIGINAL: Trail_Gunner
RE: Receiver packs
I have a 7.4 1800 lipo pack. Would that make a good power source for the rx and the servo? I would be using it in my XTM x-cellerator 2wd trk.
