Tex's first nitro MT-Savage X SS build thread
Old 01-03-2007, 09:16 PM
  #101
Lunchboxer
Lunchboxer's Avatar
Default RE: Tex's first nitro MT-Savage X SS build thread
LOL, that's hardcore bashing right there!!!
Old 01-03-2007, 09:32 PM
  #102
[]TEX[]
Ya, couple times I was doing the HOLY SH*T thing...but it's all ok now...LOL.
Old 01-03-2007, 10:28 PM
  #103
Lunchboxer
Lunchboxer's Avatar
1/8th scale nitro has always been tough....
Old 01-21-2007, 09:04 PM
  #104
[]TEX[]
Old 03-27-2007, 08:27 PM
  #105
[]TEX[]
Got some bling on the Savage, I moved the shift point to a higher rpm point and she really winds out nicely. I bought a set of RRP gears to bring her back to a normal ratio.
Old 03-27-2007, 08:29 PM
  #106
[]TEX[]
Two and a hlaf gallons and the K4.6 is running stronger than ever. Crisp launches and high end speed.
Old 06-27-2007, 07:15 PM
  #107
carldav
carldav's Avatar
ORIGINAL: []TEX[]
Motor mounted onto the motor mount bracket.
The grub screw up front is one of the updates to the Savage X SS kit. This keeps the motor from twisting forward under high torque situations.
Hi TEX,
I intend to upgrade my engine mount using the HD version. However it does not have a front screw similar to new stock engine mount. Do you think it is worth my money to buy that?
Thanks!
ID:	712519   Click image for larger version
Old 06-27-2007, 07:25 PM
  #108
[]TEX[]
Well it all depends. I assume HPI updated the mount for the 4.6
Basically that screw helps keep the front of the motor from flexing down under a heavy load.
If that mount is made of soft alum you may have issues. I think it is more for bling than functional and you won't see any noticable change in temp from those fins.
Old 06-27-2007, 07:33 PM
  #109
carldav
carldav's Avatar
I see..thanks TEX, how is your savage doing so far? any plans to update this thread with news on your savage?
Old 06-27-2007, 07:37 PM
  #110
[]TEX[]
ORIGINAL: carldav
It's doing quite well. i have about 4 gallons through it and it runs like a champ!
Here's and updated pic...
Old 06-27-2007, 07:58 PM
  #111
carldav
carldav's Avatar
Nice!
Also, I bought some "lightened" idler and Aluminum Drive gear to lightened my central tranny, do you think it really lessens the rotational mass of the transmission?
ID:	712571   Click image for larger version
ID:	712572   Click image for larger version
Old 11-23-2007, 09:26 PM
  #112
madmax22
madmax22's Avatar
Tex how long did it take you to put the savy. together??? couple hrs? seems strait forward......I think ill go with the SS not the RTR also what servos/radio/receiver do you use? will the receiver and radio from my t-maxx work for now? need servos tho
Old 11-23-2007, 09:34 PM
  #113
[]TEX[]
ORIGINAL: madmax22
It took me about two days to build it off and on. I used a Futaba 3010 on throttle and a Futaba 3305 on steering. I now use a Hitec 5645 for steering and a Novak XXTRA Rx.
The TQ radio will work just fine, but I recommend a high-torque servo for steering. A medium torque servo like the 3010 will also help with throttle control, but a standard servo will work until you can get one. I also recommend you upgrade the Tx when you can. I use a Futaba 3PM.
Old 11-24-2007, 02:08 PM
  #114
madmax22
madmax22's Avatar
I saw this on rcplanet.com the futaba 2pl 2-ch AM / 2 S3003 servos what do you think?
Old 11-24-2007, 02:21 PM
  #115
[]TEX[]
ORIGINAL: madmax22
That's also good, but you still need a high torque servo for steering. You should think about buying a nice radio once instead of buying a cheap radio you'll have to eventually upgrade.
Do this, PM turbotb0205, he is a friend of mine. Tell him I told you to PM him and let him know you are looking for an inexpensive radio with a high torque servo for your Savage. He always finds great deals on radio systems. I'm sure he'll be able to find you something.
Old 11-24-2007, 04:05 PM
  #116
madmax22
madmax22's Avatar
Ok thanks ill PM right away
Old 03-19-2009, 02:35 AM
  #117
Jem93
i can own anyone of you here!!
you should paint your new body black!!!
Old 08-16-2009, 01:25 PM
  #118
Khraih
Did you get your Savage X SS from Amainhobbies.com? Because the Savage X SS has different tires in the picture of it on Amain.
