Single Power Supply OK for 2 Chargers ?
My Feedback: (24)
I presently have an Astro-Flight 12.5 Amp power supply (Model 120) and an Astro Flight Lipo charger. Can this single power supply be utilized simultaneously by 2 chargers ? I would like to by another charger so that I could charge 2 batteries at once.
Thanks. Bob
Thanks. Bob
AZ
RE: Single Power Supply OK for 2 Chargers ?
If you don't know the wattage of the chargers you are trying to "drive" with one power supply here's the formula for figuring it out. Wattage = Current * voltage. So, say you have two chargers that each require 12 to 13 volts input and draw a maximum of 5 ams each. The total wattage required to "drive" the two charges is, 130 watts or 2 * 5 amps * 13 volts (always pick the highest voltage to be safe).
ORIGINAL: jzrf6c
If you don't know the wattage of the chargers you are trying to ''drive'' with one power supply here's the formula for figuring it out. Wattage = Current * voltage. So, say you have two chargers that each require 12 to 13 volts input and draw a maximum of 5 ams each. The total wattage required to ''drive'' the two charges is, 130 watts or 2 * 5 amps * 13 volts (always pick the highest voltage to be safe).
My Feedback: (325)
Understand that this figure is a "max" figure for the two chargers. If they are doing a small job then the power figure goes way down and is directly related to the specific job that the charger is oing at the time.
An example might be a single ps powering a single charger at max power vs. a dozen of the same chargers doing radio batteries.
