grounding the zen
grounding the zen
Old 10-16-2009, 07:24 AM
gtdad
Default grounding the zen
i was wondering how everybody grounds their zen coils. mine is not bolted, but epoxied to the side if the case....it just doesnt seem right to me????????? PLEASE HELP</p>
Old 10-16-2009, 09:18 AM
painman
Default RE: grounding the zen
How does your motor run without a ground? you need to ground from the brass side of the gray ciol to either side of the sorce coil and should be OK.
Good Luck,
Randy
Old 10-16-2009, 09:55 AM
Scott Schneider
Scott Schneider's Avatar
ABSOLUTELY ... use supplemental grounding wires on ALL my engines.
Do a search on this, there are some threads on subject within the last month or so.
Here a copy and paste of one entry>>>
You should have what you need to understand your question ?
The primary coil grounds it's self by virtue of the lamination bolting down against the cases. Secondary coil has a BRASS tab as part of the mount boss on one side, it too MUST be grounded back to the cases same as primary coil is. this happens when mounted against the tabs under carb, but gets iffy when secondary coil gets mounted above starter and on remote mounting locations.
If the path of current on the "Ground" path is interrupted by corrosion, remote mounting of coil and subsequent anodizing of parts insulating the path of current flow, you HAVE problems !!
Old 10-16-2009, 11:01 AM
gtdad
ORIGINAL: painman
Good Luck,
Randy
not real sure. that is why i asked....it actually came loose the last time i got to run it and was just flopping around and STILL ran fine ( as far as i could tell )
Old 10-16-2009, 11:28 AM
Dockman
Your RC boat is just lke you big boat **** falling off all the time.
Old 10-16-2009, 01:38 PM
gtdad
ORIGINAL: Dockman
ouch!! now you sound like crissy i don't have them dock builder pockets.....at least this one still goes down the lake
Old 10-16-2009, 01:54 PM
FlogginHarvey
you guys sound like a couple of ... (fill in the blank) ;-)
I had to use a ground wire on the Dumas Scarab because I used WHH Composite mounts...go from the brass on the coil to the case (and use some loctite on the bolt) as Scott suggested above. It works like a charm.
Old 10-16-2009, 04:15 PM
gtdad
ORIGINAL: FlogginHarvey
i'd hate to know what would be in those blanks! lol! anyhow, thanks guys. i'll get my trusty wire pliers out and get it straitened out....
-scott
Old 10-16-2009, 08:48 PM
Nosedragger
why don't you screw it back to where it belongs? why was it expoxied to the engine in the first place?
Old 10-17-2009, 09:54 AM
gtdad
ORIGINAL: Nosedragger
i bought this used in august and i am still learning and working out the bugs......this is how it was when i got it
-scott
