61cc husqvarna conversion into an Easy V?
Old 09-10-2010, 07:31 AM
Bumpinyota
Default 61cc husqvarna conversion into an Easy V?
So this chainsaw engine weighs approx 5.25lbs...
Am I completely off my rocker for thinking about trying to wedge this monster into a 46" Easy V? If not, what prop would I even start with?
Please advise
Old 09-10-2010, 08:34 PM
Bumpinyota
Default RE: 61cc husqvarna conversion into an Easy V?
54 views and nary a response?
Way too big?
Old 09-10-2010, 09:25 PM
mistycreekboats
mistycreekboats's Avatar
ORIGINAL: Bumpinyota
Way too big?
yep ........ plus it's air cooled and I believe rotates the wrong way
Old 09-10-2010, 11:31 PM
rangerfredbob
My Feedback: (13)
the engine you are thinking of (saw the post on the engine conversion board) is converted for airplane use, it's set up for a plane propeller and has the flywheel removed (aka cooling fan for an aircooled boat engine) not to mention it won't have a starter on it anymore...
you'd be better off with the ryobi engine you have like you said.
Old 09-11-2010, 01:11 AM
Justaddwata
Justaddwata's Avatar
Am I completely off my rocker for thinking about trying to wedge this monster into a 46'' Easy V? If not, what prop would I even start with?
Please advise
Thing you will find is that the motor lacks the RPM to really move a small boat. A bigger block motor like the Husky will probably respond better with a larger diameter propeller which in turn will tend to torque roll the boat more. There has certainly been more powerful motors put in smaller boats - but as mentioned already - there might be other factors at work that warrant consideration.
