All around best Sim
My Feedback: (21)
NY
RE: All around best Sim
Ah ok ... well you need to go to Rodeo's site to dload the plane and the pole.
[link=http://www.rodeo.rc-sim.de/afpro/afpro.htm]CLICK HERE FOR RODEO'S SITE[/link]
You have to set the elasticity of the cord to 0
[link=http://www.rodeo.rc-sim.de/afp_fun/afp_fun.htm]CLICK HERE TO LEARN ABOUT THE ELASTICITY[/link]
Then you have to set one as aircraft one, the other as aircraft 2, then use the TOW mechanism. Then have fun!
Rodeo is one of the biggest developers of aircraft, scenery and utilites for AFP. He's got a great AFP website ... and just so happen's to be a really nice guy.
KS
ORIGINAL: STLPilot
Yes you can assign up to 12 channels. 5 on your TX and 7 on your keyboard. No prob! You can also assign, for instance a single channel that turns your smoke on, gear goes up and flaps are up. That same channel can lower the flaps, turn the smoke off and put the gear down. So 1 switch can operate your plane for landing or flying configuration. You can use a key to drop a bomb. You can also use keys for opening canopies, glider towing release, turn and rotate nozzle for the harrier, brakes, open and close doors and bunch of other options.
You can even use AFP for control line!
Downloaded both of those planes pictured above & also that Mitsubishi Zero that drops a reserve tank. Each of them either drop their bomb or release their missle the very moment that they're on the runway without me doing anything.
I know how to assign channels from the menu (I think it's called "calibration"?) however there is no place in there that has "bombs" or "missles" to select from.
I tried reading the "read me" but it's in German!! How do you calibrate it so that it releases it by transmitter or keyboard?
Brad
#31
you could go to an on-line translator, copy and paste the readme into there and translate into english. i like http://world.altavista.com/
#32
KS
I tried that. It didn't seem to translate it very clearly into English. I followed the directions as best as they could be interpreted by me.
Do you know how to do it? Can you tell me...........in English?
Brad
Brad
#33
i have yet to try to drop bombs, but i can coordinate the corsair's folding wings/sliding canopy. i will try the bomb dropping later today. i'll let you know if i figure it out.
#36
STLPilot,
How well does AFP interface with the Futaba 7CAP Tx. Does AFP accept the mixing functions from my radio?
Can't wait to order my copy of AFP.
Danny
Danny
#37
My Feedback: (21)
NY
ORIGINAL: HK_Shooter
Yes, AFP will do whatever your radio can do once you assign your switches.
