Bud Nosen 1/4 scale J-3 Cub
#54
My Feedback: (14)
Ron thank you for the nice compliment. The gear should be here tomorrow and I am picking up some arrows for the push rods. I do have one question. The plans are not clear on where to mount the servos in the fuselage. I have the cockpit kit to install and I was wondering do I install the servos at the rear of the cockpit or underneath the cockpit kit?
#55
I put everything together and get the correct center of gravity or as close to it as possible.Use the servos and battery placement (as well as your cockpit kit and pilot to achieve that goal. I don't think you are ready to place them yet but if you do, place them as near the center of gravity as possible. The arrow shafts are going to make the tail heaver than it is now. The covering on the tail will also make it heavier. It's a judgement you will have to make. You may have to access them for adjustment so if you place them under the cockpit kit, be sure that it is easily removable. Velcro is a good means of attaching it. It is a solid means of mounting stuff like the cockpit kit (don't use it to mount servos) and can be removed if necessary to make servo adjustments. I usually wrap my battery in foam and rubber bands and place it where it will do the most good as for CG placement. .
#56
What are you going to cover it with? Please don't use a shiny film. Use a cloth type covering. Coverite makes an excellent covering for cubs. I have one that I covered about 10 years ago and it looks as good as the day I covered it. As for trim. Take your pick but I prefer to Iron on my trim rather than use the sticky back trim sheets. It's a bit more work but, for me it is more gratifying. If the ironed on edges aren't as sharp as you would like or become wavy as you put them on, use the sticky back trim tape to make it look perfect after the ironing is done.or cut the covering into strips and iron them on. That is the preferable method, IMHO.
#59
My Feedback: (14)
I will mask off the trim and paint it as well. I get a little more done. I finally got the landing gear today and installed it. I will have to paint it when I paint the plane because it is red. Here are a couple of pics of the gear and wheels. I have a 16oz fuel tank I will be installing.
#66
My Feedback: (14)
That look really nice. Is it a TaylorCraft from Sig? You do a wonderful job on the covering. I hope to start covering this week. Still have a few things to do on the plane before I start that. I too am running out of space to store my planes. I am thinking about selling a few to make room.
#70
My Feedback: (54)
Nice work there! I've got a kit I'm going to start on soon. I like the wing tube idea. I'm also thinking of making it a super cub, and adding flaps. I'll also make some more scale looking wing struts and mount the servos in each wing panel with direct linkages. The window material in the kit is brittle so I'll have to order some new stuff. I'm also looking at functional landing gear. Keep up the good work!
Steve (10-19-2020)
