Grumania SU27 flanker for MW44
#128
RE: Grumania SU27 flanker for MW44
I am not planning an airbrake. I don't think it will need it and I think cutting a hole could weaken the structure.
I have now glued the engine mount to the inside of the fuselage. For those that have built one, did you glue the mount at the top and the bottom? Glueing at the top is fairly straightforward but glueing at the bottom (i.e. to the rounded exhausts) could be a bit of a nightmare.
#129
How's the build going? I just mounted my autostart 44 in my airframe (previously assembled by Glyn Dale) I am a little conscerned about the heat sheild, I have constructed one out of stainless, coated the airframe with BVM heatsheild paint then coated the sheild. I ran for about 5 mins ; I felt the top of the fuz whilst running and it was hot! I have blisters forming on the painted outer heatsheild.(it shows evidence of scorching from its previous flights with Glyn) Is a blanket reqd between the sheild and airframe? I am just about ready to fly but dont want to fry the aircraft.
Chris
Chris
#130
When you make your stainless steel heat shield you should use small hardwood spacers to position
it a few mm from the fuselage. This will also allow air to flow through in flight.
Tor
Tor
#133
Looking good
Can you tell me how you glued the engine mount in? I've glued it at the top (with the fuselage the correct way up) but not sure what to do about the bottom (where it joins the rounded exhaust part of the fuselage). Have you glued it there too?
#134
my mounts already installed at the factory, looks like a fillet with carbon tows along the length.I cut into the tunnel to provide a drop in pull out space for the motor with mount att otherwiseits a fiddle to remove the motor. I also fitted a cover for the frontof the motor to prevent hoovering up any looseobjects off the runway(it draws air in through holes in the sides of the tunnel.
