DLE break in props
Old 02-21-2013, 03:29 PM
SCOTT42
Default DLE break in props
Hello all I know this has been asked a thousand times but im asking anyways. What is the best break in prop for a DLE 30 And 35RA as I have both. Thanks guys
Old 02-21-2013, 04:00 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Default RE: DLE break in props
i messed around with the recommended breakin prop on my 30, and felt it was a bit small...I have my 30 on a 1/4 H9 Cub and experimented with props, and IMO my fave prop is a Xoar 19x6, even though the 18x10 mejzlik looked awesome on her.. i get about 80-8100K rpm which is about right for the engine
Old 02-21-2013, 04:58 PM
Truckracer
My Feedback: (19)
From day one, I just use the prop I plan to fly the airplane with. I don't change until I find something better. In other words, no special break in prop.
Old 02-21-2013, 05:15 PM
Indiomike
Indiomike's Avatar
ORIGINAL: Truckracer
Agreed. Break in prop is not necessary. Use correct size from the start. Just don't push the engine hard for the first gallon or two of gas. A 19/8 will work very nicely on a 30/35 cc engine.
Mike
Old 02-21-2013, 06:45 PM
SCOTT42
Ok thanks guys, I guess I failed to mention that Im installing the 35 on A giant stick, and the 30 on a 1/4 scale sig space walker.
Old 02-21-2013, 09:38 PM
CK1
My Feedback: (60)
CK1's Avatar
Put a Xoar 19x8 on it tune it and fly it . You will have to retune a few times as the engine breaks in but the 19x8 won't over load it and will give you the best overall performance If after it broken in and you need more speed you can go to a 19x10 , less speed more pull 20x6 scimitar style prop (I use the Red Wing RC 20x6 on mine )- only after a few gallons of flying time on break in with the 19x8 . On the 35 you may be able to use a 20x8 after its broken in enough.
