HummingBird
HummingBird
Hi,
I have a Humminbird with a 370 High Perfomance Motor and a direct drive tail motor, the problem is that the heli at high speed begins spinnig to the left because the tail motor does not counter the torque of the main motor the same happens with the standard motor. I'm thinking on using a pinion to work with the stock tail blades or to adapt the stock tail blades to a direct drive. Does anyone have a opinion on this.
Keyser
Keyser
