MS Air Filter Damaged by Spur Gear????
AB, CANADA
Just changed my spur gear from 38T to 40T & my clutch bell from 15T to 14T.... Noticed my Motor Saver Air Filter has been cut by the Spur gear as it rotated... When I installed it, there was enough clearance (although not much)... Has anyone else had problems with this, whether with aftermarket parts or not? Any recommendations?
RE: MS Air Filter Damaged by Spur Gear????
i was gonna do it but the m/s snorkle might fit on the tm523 without obstructing the spur
ORIGINAL: kliff
A littla adaptation, but modify the MS filter housing to fit the REVO snorkle, and glue the 2 together....
