I need a solid axle
I need a solid axle
I need a solid/straight axle and diff that will handle 40-50 mph, possibly more, for a project I'm working on. It needs to be at least 1/12 scale, but I would prefer 1/10 or 1/8. I was considering the Wheely King axle, but because the truck isn't that fast, I can't see it being that strong. What I would like, is aluminum, and a 4-link setup for both sides, plus a place to mount shocks on the rear.
I hope you guys can help, thanks.
RE: I need a solid axle
i had a wheely king that i modded to a crawler once. i had a 55t motor, geared low, diffs locked. i did eventually snap something in the axle, but that only happened when both front wheels were stuck and COULD NOT MOVED, yet i gave it full power. now, that motor put alot of torque on the axle before it broke. so, i would be willing to bet they could handle some serious speed. i know there are some vids on youtube of wheely kings with brushless motors on them(for speed, not crawling)
I built a 1/10 scale Straight axle desert truck last year using the AX10 axle. Not sure how fast it was going but it handled the VXL motor on 3S without a complaint. I'm guessing it was well into the 50 mph range.
ORIGINAL: kaiser01
kyosho just released the mad force in an electric version, it ''may'' be able to hit those speeds.
ORIGINAL: nitrosportsandrunner
those are nice, but wicked pricey! i have also considered a wheelyking axle for a project i would like to do.(front engine, rear drive with no tranny) but even those cost a fair amount.
