Giant Tiger Moth
Giant Tiger Moth
Old 10-31-2010, 08:03 AM
fryfly
My Feedback: (8)
Default Giant Tiger Moth
Anyone!!
a few years ago there was a manufacturer that was offering a GIANT Scale ARF Tiger Moth. I think it was a 1/3 scale and the wingspan was close to 100 inches or so, I think. Does anyone have any idea who was offering this particular model. It also had the flying wire controls and I believe it would fly with a 50cc engine. Any help would be appreciated.
thanks in advance
Old 10-31-2010, 09:01 AM
Warbird Joe
Warbird Joe's Avatar
Default RE: Giant Tiger Moth
Here is a link to look at. I did a pretty extensive search and this is all I could come up with. I hope this helps.
http://www.raidentech.com/dehadhtimo12.html
Joe
Old 10-31-2010, 12:19 PM
fryfly
My Feedback: (8)
that wasn't the one I was thinking about, but thanks anyway. I seen it advertised back in 2008 and 2009 but have not been able to find it again. It was the basic yellow version you see everywhere but it was close to 90 or 100 inches if I'm not mistaken. I guess I will keep looking.
Thanks.
Old 10-31-2010, 08:42 PM
deadstickdan
Not a Tiger Moth but this may fulfill a need for a large vintage bi-plane:
http://www.maxfordusa.com/gm-jenny-105-soild.aspx
Dan
Old 11-01-2010, 09:32 AM
fryfly
My Feedback: (8)
Thanks, Looks like a pretty nice bird to fly.
Old 11-11-2010, 01:11 PM
fryfly
My Feedback: (8)
just to let you guys know, Maxford is offering a giant scale Tiger Moth (105")
it's under the ARF, gas/glow airplanes
Old 11-11-2010, 01:39 PM
ec121
A friend has one of the 105" Jennys from TBM. They had them on clearance last winter. It is likely the same as Maxford's. Everything on the tail is pull-pull. Uses a 50cc engine. It is a big kite. Lots of flying wires to rig.
Old 07-18-2011, 07:07 AM
Planejaw
My Feedback: (53)
I just purchased on of the new Maxford 105" Tiger Moths. Ordered it on Father's Day weekend during one of their specials. No shipping!!
First impressions: This is a pretty large aircraft. It came shipped in two large boxes. OK packaging, but one wing had a hole punched in it from the strut-mounting bracket in another wing. Fortunately, they give you a couple of pieces of covering to use for patching repairs. Unfortunately, this repair was on the top surface of the lower right wing, so it's kind of visible. I'll have to see if I can hide it. Use low temp on the sealing iron, as the covering shrinks up and rolls its edges quite quickly.
Otherwise, large control surfaces on the empennage. Lots of plywood in the fuselage structure, with elevator and rudder braided cables pre-set in the fuselage. Very nice large fiberglass cowl...just wish it didn't have that goofy "Woody-Woodpecker" head emblazoned on both sides of the cowl!!
Hinged side doors on both sides of each cockpit...though one hinge does not appear to have a piece of wire holding the hinge together. Should be an easy fix.
Nice hatch on the floor of the rear cockpit, held in by magnets, giving access to servos. Lots of room in the fuselage for almost anything you'd like to put in there.
Tires are foam mounted on aluminum painted wheel hubs. With no real "suspension" to the landing gear, you will need some nice 5-6" Du-Bro air filled wheels to take up some shock. May need to design some type of suspension in the landing gear area.
Engine box is not affixed to the firewall, allowing you to adjust it before epoxying/bolting it into the firewall, to fit your particular engine. Even though the instructions say a 50cc engine is needed, I could see a 50cc levitating this bird straight up. I would think a 30cc would be more than enough, but the weight in the nose would likely be beneficial. I've got a DA-50 to put in the business end...which is what the instructions show.
This will be a Fall project, so I'll keep posting information on the build.
Old 07-18-2011, 05:33 PM
kerwin50
Here's one from power-line hobbies.
I've had a few dealings with them and they've always gave me good service
http://powerlinehobbies.com/singleoutput.php?id=291
Old 09-19-2018, 02:05 PM
Klemen
hello guys!
I bought this plane cca. 2 moths ago.
For power I have added DLE 55 with pitts muffler from sgshobby for 25€ and it is much better like original exhaust
I do it some design changes,because now looks better
here is some pictures and video of almost maiden (2nd flight after some changes)
Old 11-13-2018, 03:51 PM
Klemen
another 2 videos:
Old 06-30-2024, 06:35 AM
cymaz
cymaz's Avatar
Just picked up one secondhand a few months ago….
https://forums.modelflying.co.uk/ind...tigermoth-105/
Old 09-05-2024, 01:01 PM
FLOIQFPV
Nice flying!
