Weatronic help please...
Hi,
While setting up a model with 12-22RIIIGyro I disconnected the battery went away for a minute ,came back and plugged the battery in,but.. there is absolutely no response ,I changed to another battry, same result...I switched to the other battery inlet again no answer.
Is there some kind of 'fuse' or something in there ,am I just doing something stupid?
Thanx in advance...
Eray
Thanx in advance...
Eray
RE: Weatronic help please...
Thank you Dave, unfortunately have tried that with no success...Guess it has to go back to Germany...Am very confused though ...I am a very satisfied customer till now.
Regards
Eray
Regards
Eray
Eray,
Your R12-22 is equipped with LEDs both on the Rx itself, and on the on/off switching board. Do these come on at all?
In normal circumstances, you switch it on by removing the jumper (Red "remove before flight" switch pin). On powering up the Rx does a battery check and then the LEDs light up depending on the status of the Rx. The green LEDs should light up in some fashion, depending on status and Rx type.
I suggest you check your batteries are charged to 8.4 volts, check they are plugged in correctly, and check the jumper is removed from the switching board.
If no LEDS come on, then I suspect it will be fried.
Hope this helps..
Hope this helps..
Roger,
No sign of life there unfortunately...But do you think not using the switchboard but just pluging in or out the battery directly could have caused some damage?
Eray
Eray
