Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
Cessna 195 DLE 30 Rear Carb Mounting
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 11-02-2010, 10:28 AM
Mark Dennis
Mark Dennis's Avatar
Default Cessna 195 DLE 30 Rear Carb Mounting
We have created a step by step installation guide for the DLE 30 Rear carb to be mounted in our Cessna 195. The airplane was originally designed around the side carb DLE 30 but it is very simple to mount the newer rear carb version using this guide.
Please let us know if you have any questions.
Mark Dennis
Tech Support
Aeroworks, Inc.
4903 Nome Street
Denver, CO 80239
303-371-4222 ext. 105
File Type: pdf
Mark Dennis is offline
Old 11-02-2010, 04:38 PM
smperry
Default RE: Cessna 195 DLE 30 Rear Carb Mounting
How timely, I just started work on mine today. and was wondering how I was going to accommodate the rear carb.
sp
smperry is offline
Old 12-08-2010, 08:14 PM
smperry
I'm at the waiting for decent weather stage with my Cessna. The mounting instructions for the rear carb DLE-30 were clear, straight forward and I had no problems. In other words, virtually idiot proof.
Just out of curiosity, are there any plans to make available some decals for the N numbers and such?
Only hitch in the whole assembly process was when I forgot to drill the hole for the throttle linkage, tried to drill it with the engine in place and broke the plastic fuel fitting. That required a new carb. I'll have the broken fitting replaced with a brass fitting and keep that carb for a spare. Drilling out the broken fitting is not part of my skill set, so I'll have to impose on a buddy who knows what he is doing.
A very enjoyable build, thanks Aeroworks
sp
smperry is offline
Old 08-20-2011, 02:07 PM
labebe
Mark, I just finished my Cessna 195. install a 180 saito glow as the manual says I have a problem when filling the fuel tank and the engine carburetor choke whole or completely filled with fuel, it appears that the tank is above the carburetor, is this correct?? How can I solve this problem I couldn't fly my cessna.
Alex
labebe is offline
Old 09-09-2012, 01:56 PM
jimt50
Alex,
I had the same problem with mine. The problem is that the fuel tank is to high above the carburetor so the fuel is just folowing gravity. I have tried to use a Kline fuel regulator which solved the problem but the engine was very hard to adjust and would not run right. I was getting a lot of dead stick landings. So the other way to fix it would be to lower the fuel tank floor so that the carb would be higher than the tank. Plus the Saito runs through fuel like it's water. Be aware of the flight time. These are the things they don't tell you about in there reports.
I am taking the Saito out and putting in a DLE30. Jim
jimt50 is offline
