q about rs4 3
q about rs4 3
Just check the dimensions of the pipe before you buy it.Like length and width and look to see if the pressure fitting will be right side up if it even has one at all.The Rs4 3 pipes are funny because of the engine placement I guess but the pressure fitting on my last pipe was up side down and it didn't fit right because the pipe was to long and to wide.
