Over revving at startup
Old 08-03-2003, 01:58 AM
labattize14
Default Over revving at startup
hello again
When i start my OS max .15 it seems to rev up to high
is there a way to get a ggod idle setting? I have messed with the carb hole setting and tried everthing but i cant seem to get a goog ideal. When i drive it it seems to be open all the way up untill i apply the brake to slow it down. Could this be the reason that ny clutch shoes seem to slip after about 2 tanks of gas? The car is a RC10 not that it really matters.
Please help a newbie
Thank you,
Mark
Old 08-03-2003, 02:23 AM
Lil Evil 260
read the manul. look for the starting settings and well, start from there
Old 08-03-2003, 02:43 AM
labattize14
I have read through the manual and set everthing back to factory but it still seems to rev up. Is the screw w/ the spring coming loose. Basically what should your car idle at?
Mark
Old 08-03-2003, 03:31 AM
dan1220
dan1220's Avatar
idle screw should be set so that the carb is open 1mm
