GWS S03N-II+ HP and GWS S03N-II+ D
What size, torque, speed of servos that you wish to installed on your helicopters?
Tell me what is your wish? GWS will try our best to meet your demand, make your dream to be realized! Yet, less expensive to be paid for!
I hear about Futaba S9252 is one of the most popular one among Asia coutries. What's about your choice in USA or Europe countries?
GWS S03N-II+ HP MSRP$10.00 2BB$12.00 MG2BB$22.00 for 4.8~6.0v
4.8v 8kg 0.148sec.. 6.0v 9kg 0.130sec.
GWS S03N-II+ D HP2BB MSRP$17.00 MG2BB$27.00 4.8~6.0~7.4~8.4v
4.8v 8.2kg 0.134sec.. 6.0v 9kg 0.114sec.
7.4v 10.5kg 0.102sec.. 8.4v 11.4kg 0.095sec.
As usual, GWS always more gear ratios for your choice of application to get the best optimization!
GWS new servos S03N-II+F HP and GWS S03N-IIF D HP2BB will be avalible soon. Yet, there another speedy choice GWS S03N-IIXF HP and GWS S03N-II+XF D HP2BB. ( F=Fast, XF=Xtra Fast D=Digital ).
GWS S03N-II+F HP MSRP$10.00 2BB$12.00 MG2BB$22.00, for 4.8~6.0v
4.8v 7.0kg 0.131sec.. 6.0v 8.0kg 0.123sec.
GWS S03N-II+F D HP2BB MSRP$17.00 MG2BB$27.00, for 4.8~6.0~7.4~8.4v
4.8v 7.0kg 0.110sec.. 6.0v 8.1kg 0.098sec.
7.4v 9.1kg 0.081sec.. 8.4v 9.8kg 0.074sec.
GWS S03N-II+XF HP MSRP$10.00 2BB$12.00 for 4.8~6.0v
4.8v 6.0kg 0.099sec.. 6.0v 6.8kg 0.086sec.
GWS S03N-II+XF D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v
4.8v 6.0kg 0.089sec.. 6.0v 7.0kg 0.078sec.
7.4v 8.0kg 0.070sec.. 8.4v 8.5kg 0.064sec.
You may easily compared with a F brand most popular S9252 servo specs as below: Price:$84.99
But GWS analog only $10.00, Digital type only $17.00. While both versions performance result better than S9252.
http://www.servocity.com/html/s9252_...l_bearing.html
Control System: +Pulse Width Control 1520usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8 Volts Only
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60 degrees at no load
Stall Torque (4.8V): 92 oz/in. (5.5kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: All Nylon Gears
Connector Wire Length: 12"
Dimensions: 1.6" x 0.8"x 1.5" (41 x 20 x 38mm)
Weight: 1.8oz. (50g) All Nylon Gears
Who give more torque? Who run faster? Yet, GWS S03N2 is way much lighter! All of those GWS S03N-II+ servos weight only 33g when with All Nylon Gears, with full metal gears will be 60g of the weight.
360 Modifiable: Yes
