Aeroworks Extra300 QB 60-90 anyone?
Just wanted to know whether anyone has flown the new Aeroworks Extra300 QB 60-90 ARF. I am comtemplating purchasing these for a 75AX or FS91SII engine
http://www3.towerhobbies.com/cgi-bin...?&I=LXZNP7&P=0
Ameyam
Ameyam
RE: Aeroworks Extra300 QB 60-90 anyone?
<span class="Apple-style-span" style="font-family: Arial; ">I've got one with an old OS 1.08 2-stoke and it is a rocket - I'm off the ground before I get to 1/4" throttle and will go vertical forever. Haven't found anything it can't do and had about 30+ flights so far with it. The 75 should be just right since it will keep the weight down - mine is overpowered by about 25%. Build quality is top notch, but the hardware is hit or miss. </span><div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); font-family: Arial; font-size: 12px; "><div></div><div>If you do get it, make sure you're careful with the fuel tank assembly, it is not the best stopper design and mine popped off with a full tank of fuel... replaced with a sullivan stopper and had zero issues since. </div><div></div><div>Tim</div></div>
