trx 3.3 upgrade and fuel
Old 01-24-2011, 10:32 PM
superflyboy1988
Default trx 3.3 upgrade and fuel
im look for upgrade for my trx 3.3 in the way of fuel and head shims or other mods like that i would also like to know what is the best % of nitro to run in it i run oddonell in my boats and would like to use it in my car too
thanks for any info
Old 01-24-2011, 11:01 PM
378's Avatar
Default RE: trx 3.3 upgrade and fuel
20% nitro and the stock shims are fine. If you want more power out of it, get a better exhaust system.
Old 01-24-2011, 11:04 PM
superflyboy1988
like what
Old 01-24-2011, 11:06 PM
378's Avatar
What pipe you select depends on a ton of factors. Some pipes give you tons of low-end, some midrange, some high-end, some can do a little of everything, and still others just kill the power across the board. I couldn't name you a specific pipe to use.
Old 01-25-2011, 05:34 PM
rc awesome
rc awesome's Avatar
But most stock pipes suck power wise, and they don't sound as good.
Old 01-25-2011, 08:12 PM
superflyboy1988
but do i need to do anything to upgrade to 30-40 % nitro
Old 01-25-2011, 08:22 PM
378's Avatar
I would advise you not tempt your luck with a 3.3 on that stuff. IF you're going to start putting 30% and 40% in the tank, go to a stronger engine. If you insist on it, though, you will need to:
Fit the Davis Diesel aftermarket conrod. 2.5s and 3.3s have a weak rod that likes to snap on 20%. Twice that on the stock rod is BEGGING for your engine to do an impersonation of a grenade. Here's a link to it: http://www3.towerhobbies.com/cgi-bin...?&I=LXVHW4&P=Z
You will need to shim the head considerably.
You will need a colder glow plug.
You will need to fit a better exhaust system.
Old 01-25-2011, 09:26 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
If it were me, I'd run it on 20-25% nitro (I run 25% on MC59 plugs and havent had a single problem with the 2.5r's or 3.3's I've had) with a good pipe. THS, Buku, and CVEC come to mind. The Resonator made good power down low, but there are better options for the money IMO. I have a CVEC in the rustler - I'll probably get a THS or Buku for the Jato I have.
