rebuilding carb question
Old 01-26-2011, 06:24 AM
Telecaster
Default rebuilding carb question
when resealing a carb should I oil the o-rings before I put them in?
I know in other circumstances it's beneficial.
Any other not so obvious advice?
carb is from a pro 15
Old 01-26-2011, 08:11 AM
Argess
Argess's Avatar
Default RE: rebuilding carb question
I usually put a light coat of grease on the o-rings for the mixture needles. The carb base o-rings I leave dry.
I do use a bit of RTV around the upper base of the carb so it seals to the block when I insert the carb. Put it on the carb, not the block, or you might accidently push some into the crank area.
I also cover the pinch bolt (both sides) with RTV once it is assembled.
Old 01-26-2011, 08:40 AM
Shenanigans
My Feedback: (12)
Many use associated's green slime to lube the needle o-rings...this helps seal them, and makes it a little easier to install them if its a tight fit.  Grease works too.
Old 01-26-2011, 09:46 AM
Telecaster
I think I just rebuilt this carb just to figure out that I had a bad EZ Start
*facepalm*
Old 01-26-2011, 09:47 AM
Telecaster
I feel pretty stupid right now
Old 01-26-2011, 12:17 PM
Argess
Argess's Avatar
ORIGINAL: Telecaster
I feel pretty stupid right now [img][/img]
Don't be silly. We all go around in circles sometimes. Just think of all you learned !
Old 01-26-2011, 12:29 PM
cooldriver385
Ya those blue wires on the EZ Start are not exactly the greatest at glowing things. So a glow igniter will get the job done right.
Old 01-26-2011, 12:52 PM
Shenanigans
My Feedback: (12)
agreed. I ditched my ez start wires for a glowplug ignitor on my jato. what you lose in convenience, you make up for in wondering why the heck the engine isnt turning over because the glow mechanism isnt working.....
