Official Tamiya TB03 Thread
Old 02-08-2011, 10:18 PM
Haddi Taha
Haddi Taha's Avatar
Default Official Tamiya TB03 Thread
I don't think this thread may be as poplar as the other ones but here it its if you need tb03 help.
Mine has some upgrades, arta garayia shell, 8.5t ezrun 4000kv motor powered by 3s lipo.
Its a blast to drive and love the sound the shaft makes at high speed
Old 02-09-2011, 05:41 PM
dragnse7en
Banned
Default RE: Official Tamiya TB03 Thread
Have you checked the balance of your center drive shaft? Roll it along the corner of a table to see if it wobbles or not.
Old 02-11-2011, 09:50 PM
Haddi Taha
Haddi Taha's Avatar
so an uneven drive shaft makes cool noises? </p>
Old 02-12-2011, 08:04 AM
dragnse7en
Banned
ORIGINAL: Haddi Taha
so an uneven drive shaft makes cool noises?</p>
It could make some noise but not always at first. It will definitely make noise when the imbalanced shaft prematurely wears out bearings and bevel gears.
Look for a noise that sounds like a wobble and then check the gearbox's bevel gears.
Old 02-12-2011, 05:47 PM
Haddi Taha
Haddi Taha's Avatar
it only makes the noise at high speeds when driving, check out this video i found.
http://www.youtube.com/watch?v=U3exonc6Jzo
credit to the video uploader
Old 02-12-2011, 07:44 PM
ElectricGuy007
That's some really good driving Haddi. [8D]
Old 02-12-2011, 10:56 PM
Haddi Taha
Haddi Taha's Avatar
thats not my video as i wrote, credit to the uploader. but yeah the driving from the that guy is pretty good.
Old 02-14-2011, 09:04 PM
Haddi Taha
Haddi Taha's Avatar
i roled the centershaft as you said, no wobbling. Some say itts a characteristic of a shaft car with a smooth drivetrain.
Old 02-15-2011, 09:06 AM
dragnse7en
Banned
Does your car sound anything like this? The AE TC4 is shaft-driven:
Old 02-16-2011, 01:07 AM
Haddi Taha
Haddi Taha's Avatar
sounds similar but because he has twice the power and more so he's is louder. But the sounds seems to goabit once the tires have stop squelling and gain grip. Anway its pretty cool, it scares all the belt driven car drivers when they hearthe tbon the track
Old 02-16-2011, 01:11 AM
Haddi Taha
Haddi Taha's Avatar
the next group of hopups eading my way
 Spec-R Gear Differential
 Tamiya Diff Fluid 5000#
 Tamiya Carbon Reinforced A Parts
 Tamiya Carbon Reinforced M Parts
 Tamiya Carbon Reinforced K Parts
 Tamiya C Parts
 Tamiya D Parts
 Tamiya E Parts
 Tamiya Universal Shafts
Old 02-16-2011, 08:56 AM
dragnse7en
Banned
Tamiya C Parts
Tamiya D Parts
Tamiya E Parts
I still have all the kit's original universals, but I want to change out the rear blue aluminum ones with some stronger black steel ones. The rears are 44mm and the fronts are 46mm. I like to use some 48mm ones for both the front and rear, just like my older car, but I want to see how well these wear before I make that decision.
Did you already get #54147 TB03 Carbon Reinforced Lower Deck?
Old 02-16-2011, 10:08 PM
Haddi Taha
Haddi Taha's Avatar
the cf deck has been ordered so its not on my to get list, wainting for it to come. I dont like the alloy rear lightweight swing shafts, bend to easily, so i am getting steel 44mm for front and back for the tb03.
By the way, if you were to remove the front cvd and drive your 4wd touring car so its 2wd is it going to be slower?</p>
Old 02-17-2011, 09:59 AM
dragnse7en
Banned
Yep. I tried 2WD once and the rear wheels had double duty with all the weight of the car instead of "half" its weight. It went the same speed but took longer to get as fast.
Old 02-17-2011, 09:11 PM
Haddi Taha
Haddi Taha's Avatar
i did 2wd when my diff acted up and it was terrible, you can barely turn without spinning out, but 4wd i just amazing.
Old 02-20-2011, 12:54 AM
Haddi Taha
Haddi Taha's Avatar
this car can take on trf416's and xray t3's if set up properly.
I heard a story from a friend with a tb03 who drove his tb among other cf belt cars and was very succesful. The track owner was impressed and bought a tb03. The track owner was so impressed he sold his xray t3 to get another tb03.
Many guys over at rctech are having good success with the chassis, several hopups are needed to get the car to perform that great.
Old 04-17-2011, 11:39 AM
dragnse7en
Banned
Any updates on your TB03 Haddi?
Old 04-17-2011, 08:23 PM
Haddi Taha
Haddi Taha's Avatar
I have got it running again 2 weeks ago, installed a 3s LIPO yesterday and it flies. The 4000kv motor is working well. I think it does 50mph which is enough for the meanwhile. I know have enough parts to build 2 more diffs but all the dff problems have now gone away [&amp;:].
Need more tires
If i can i will take a video when i go to play indoor soccer tonight in the parking lot.
Old 04-18-2011, 08:34 AM
dragnse7en
Banned
Good to hear about those diff problems gone now - good deal!
Old 04-18-2011, 09:53 PM
Haddi Taha
Haddi Taha's Avatar
shoot i royally overgeared (like buy 3 0.6 metric gears, thats alot) so one of my motors soler for the wire melted off. Need to solder it back.
Old 04-18-2011, 10:11 PM
dragnse7en
Banned
yeowch!
Old 04-19-2011, 03:05 AM
Haddi Taha
Haddi Taha's Avatar
The ezrun motors and esc are very tolerable to heat (under the right applications) it took me 12 months to smoke a 35amp esc geared 1.25 rollout. It went very hot but never quite.
What i like about ezruns is that the motor wires plugs always melt off before you damage your motor in my experience. I have now geared down from 1.25 rollout to around 1.05.
Gearing is so weird, some times you have to stick to 0.9-1.1 rollout and sometimes you can gear to the moon.</p>
Old 04-19-2011, 07:02 AM
dragnse7en
Banned
Sorry Haddi, you have totally lost me on your gear ratio numbers. Tonight I will start another article; finding your car's gear ratio and Final Drive Ratio, no matter what type of vehicle it is. Yes, there's a math formula for that. Stay tuned . . .
Old 04-19-2011, 06:41 PM
Haddi Taha
Haddi Taha's Avatar
Cool I will be looking forward to that. I was taught to gear to 0.9-1.1 rollout and gear down or up according to heat build up.</p>
