Bad motor or ESC or what?
backround:
hpi sprint 2 drift (rtr)
Gm Racing V12 ESC
HPI driftmeister 13T motor
After playing with the car for maybe 5-10 minutes it will stop moving... the wheels still turn fine and everything but the car wont go forwards or backwards. the ESC led lights up at nuetral Full throttle and Full Reverse as it should and shuts off in between, but nothing.
Nothing is hot like its over heating.. it just stops.. sometimes it comes back to life after a minute or a push or something random. i pulled the motor it turns like it has since the day i got it ( it is used but in good condition)
im lost.
<br type="_moz" />
Gm Racing V12 ESC
im lost.
<br type="_moz" />
IL
ORIGINAL: dirtyrican987
backround:
Gm Racing V12 ESC
im lost.
<br type=''_moz'' />
backround:
Gm Racing V12 ESC
im lost.
If you don't have a volt meter handy...try swapping a different motor to see if it's a burnt out. If your ESC is still lighting up as it should then that's not the problem. Chances are it sounds like a motor almost dead. I've had that happen to me before several times with those cheap silver can Tamiya motors I blast around on 3S with lol. I'd give my rig a kick and then the motor works again.
They'd actually smoke out...then I'd clean them out with motor spray...relube the bearings and off I go again. I have so many of those from kit builds laying around it doesn't matter for me. Those silver cans sure can take a beating!
also check all motor connections, a bad soldering job can be to blame. It happened to me, i did a weak soldering job and covered the bullet plugs with the shrink tubes but i yanked it a bit to hard so i unknowingly put it in my car and the esc would work but not the motor, so i removed the shrink tubes and one of the connections will come off every time i accelerated.
