Cars acting up
Cars acting up
<span class="messageBody">hey i just bought one of exceed's brushless motordrift cars (blue 350z) and got it yesterday and i ran it once and it ran fine that night i took the battery out to charge it and the next day when i plugged in the battery the car is real jumpy like i keep taping the throttle and sometimes doesnt even move (batteries completely plugged in) and then the led lights flash green and the fan and whole motor shuts off. idk whats going on with it and need help thanks. oh and everything is brand new so i have no idea whats going on</span>
RE: Cars acting up
1. when your batteries came off the chearger, were they hot? did you leave them for as long as the manul states?
2. If your using a nimh or nicd battery, the esc could be in lipo mode so it thinks the voltage is too low and cuts off.
3. Check the positioning of the reciever wire, make sure its not touching and a least half a cm away from metal, carbon fibre or any othe electricals including wires.
RE: Cars acting up
http://www.nitrorcx.com/51c806-pro-b...lue-24ghz.html
this is exactly how i got it havent touched a thing
RE: Cars acting up
ok so what i want you to do is take pic of the cars electronics so i can identify the esc.
have you tried the 3 steps i told you before?
Do you have access to another battery (possibly borrow from a friend) to test to see the problem.
If you still can't solve the problem then your lhs will be able too.
