Rustler in the grass
MN
Hello-
I am about ready to purchase Traxxas Nitro Rustler, but I want to be sure that this vehicle will perform well in grass. I will be running this vehicle mostly on grass.
Bjfrankl
Bjfrankl
RE: Rustler in the grass
ORIGINAL: bjfrankl
Hello-
Bjfrankl
Hello-
Bjfrankl
Being 2 wheel drive, the N. Rusty will probably wheelie more and spin the tires a bit more than on pavement.. If you want constant traction, you might want to look at a 4wd.
(You won't want to break a new engine in in the grass - going to need a parking lot for that.
ORIGINAL: rc awesome
At slow speeds it will get stuck in thick grass. It'll do fine in short grass though</p>
MN
I bought the electric brushed version today, but I am going to return it because I think that I will get bored with it. I haven't decided if I am going to get the nitro version yet or not.
Bjfrankl
Bjfrankl
SK, BANGLADESH
if you're going to get bored with an XL5, you're going to get just as bored with the nitro version
neither will be much good in any grass at all
ORIGINAL: sloppyG
If you're going to run mainly in grass and very little pavement or other hard surface, perhaps you might want to look into an electric 4WD. These arent as critical when it comes to operating temps as nitros are. Lots of running in grass can overheat a nitro, so thats something to consider. Either one will be fun on the right terrain.. Grass only would get boring to me without 4WD.
MN
So, if I am understanding Traxxas correctly, I am able to upgrade if I want more speed. Is this correct? The box says 35mph, but it doesn't sound like the Ruster electric (brushed version) will reach this speed without upgrades. If I would've purchased the brushless version with a better battery pack, then I would be looking at more speed/power, correct? I fly nitro airplanes, thus I am new to the rc car scene.
Bjfrankl
Bjfrankl
SK, BANGLADESH
the rustler, both nitro and electric is a very old design and very overpriced for what you get
no stadium truck will perform well on grass unless it's been cut very short
my jato is marginal on grass, unless it's like a scooer field w/very, very short grass (of course).then it's great. i don't see how a rustler would be much better in not-too-short grass.... even my 4wd ten-t doesn't love longer grass, but it will slog through it. isn't this the kind of stuff 4wd monsters (and maybe not stampedes) are made for though?
My Feedback: (12)
MO
If your running in grass primarily, a 2wd stadium truck isnt what you should be after. At the very least you want 4x4, and you ought to be looking at MT's and Truggy's...electric or nitro. Nitro's everheating in the grass is silly IMO...if you have the engine tuned correctly it wont be an issue.
Im not saying 2wd stadium trucks can't run in the grass, but your better off looking for a setup that can thrive in the grass. 4x4/ground clearance/torque
If your going to run a 2wd 1/10th scale in the grass get some Moabs or some rock lizzard tires and strap them on all four corners. Works excellent!
