HELP I have fking had it with this engine
hey guys, so i have been in this damned hobby for less then a year now, and i know what im doing, i have a savage X and a tmaxx.
The ****ty 3.3 tmaxx engine i sol it cuz it was just too much to deal with so i bought a dynimight engine for it and i have had 0 and i mean 0 problems with tuning or running the engine and truck fires right up on the first roto start turn and tunes like a dream.
Now fast forward a lil to my savage X i got the bright idea to so call SEAL my engine and i did a big noob mistake by hammering the carb pin all the way out causing damage to the carb, i finnally bought few used engine with carbs for really cheap.
Now heres the problem i cant for the hell of me keep the truck on, fires right up and dies "and no the engine is not shot and it has tons of compression left in it" if i get it to stay on and it ideals good i cant get it to shift, i try to play with the HSL and the temp shoots over 250 with a ton of blue smoke coming out of it.
I tried to change the shifting time and still it wont shift it reves up to its peak and then stays there, I did get it to shift once yesturday and i havent seen it shift since also when its running and i take my finger off the throttel it keeps humming then it ideals.
Can some one help me please, i have 2 engines for this thing and a brand new engine thats sitting in a box, both the used engines have alot of compression left in them and i dont want to drop in the new engine in it HELPMEPLEASE
RE: HELP I have fking had it with this engine
why would you seal the engine? did you have problems, and figured sealing the engine would fix it? (rarely is the problem). go over the fuel system completely, check the lines , tank for crack's, also did you maybe lose one of the o-ring's off of the needles in the carb when you changed the carb body?
i didnt have any problems before, before i messed up my carb just thought it wouldnt hurt to seal it but i messed it up in the process of sealing it now i got another carb but im having a hell of a time i have the carb open more then normal for it to turn on
hey guys, so i have been in this damned hobby for less then a year now, and i know what I'm doing,
Seems to me if you rethink the above statement, and learn about the nitro engines, you may discover the solution. The attitude in your comments and verbiage leads me to think you are both frustrated and emotionally unstable.
Good luck
Dennis
ur too funny my friend, i know alot about nitro and if u look around this is the first time i may be asking for help in a post :P also if ur here just to nag at me and be a smart ass then please dont bother posting
ORIGINAL: BigGrump
Good luck
Dennis
Good luck
Dennis
You have such an atttractive way with words, but sorry, sweet talking me will not drag the soilutions out. They do exist, but you are going to need to read and study, just like the rest of us.
Good luck, and remember this hobby is for fun.
Dennis
The poor engine needs a good tune
Sealing the engine is actually very simple. Where the carb meets the motor is where you seal. Then where the back plate meets them motor is the other spot you seal. No need to take anything apart. I use Lucky 7 to seal my motors. It does sound like you have an air leak. Also like mentioned above check your fuel lines and tank. Something that most forget about is the glow plug. Often they will start the engine but once a little throttle is given they die. 250 temp is not bad when it gets above 275 then you need to richen it up. I keep my motors between 240-260 the sweet spot is 245ish. When then engine seems sluggish lean it out.
Remember even if the temp is high its ok if there is still visable smoke coming out the exhaust at full throttle.
hey moezer,i got the same problem with my old 5.9.ive sealed that engine,changed tank n fuel lines,replaced gromets for the manifold n pipe and that b i t c h still gets freek ing hot qik and its runnin hell rich to try keep it cool.ive had the temp up to 366f.the only thing i havent done is the engine bearings.i bought an lrp.30 instead.i cant get on n i t r o c a r n a g e.how bout u?
used carb...could have debris trapped in the fuel passages....would make it impossible to tune..... I have to clean the carbs on our race engines all the time to keep thenm running in prime condition...
ORIGINAL: llkoolskillet
aussiexl59
The site is down its up now but on a diff domain.
supertib
Itook the engine apart and gave it a good cleaning 2 days ago and i havent tested the truck out since, rain came in.
But the engine did fire up every time with the first pull after i cleaned every thing up.
Just need some time to test it will up date laters thanks guys
