CEN .46 idling too high
Hi to all,I recently bought a newCen Genesis .46 truck and im having a problemwith getting this truck to idle easily..I broke it in by Cen Specs and now trying to tune the truck ,but it seems its idle is high no matter how much im adjusting it..This is my first Cen truck so iont know much about this engine and tunning it..Can iget some suggestions please...I also tried to setting needles back to factory setting and still no luck..thanks in advance for any help...One more thing if there is any upgrades or tweeking on this truck that i could do please let me know also..
RE: CEN .46 idling too high
hi i just got a second hand genesis off ebay ant had time to use it yet as im waiting for parts roto start and backplate can you tell me if these trucks are good or not and what is the best needle setting thanks bryn
If you broke your motor in the best settings I found out are two and a half turns out on the high end the low end is one turnout from flush and the idle is pinch the fuel line and if it revs up for 3 to 5 seconds and then cuts out that's proper that's what works for me and it works every time on one pole it starts and stays running
