DLE 20cc
DLE 20cc
Hi guys
What do you think of putting the DLE 20cc in the Seagull 540 Edge 60-90 ARTF.Will this engine have enough power?
1 Post
RE: DLE 20cc
ORIGINAL: Bernard Groenewald
Hi guys
Hi guys
Bernard,
I beleive the Black Horse Edge 540 .60-.75 is similar to the Seagullplane you have.
the DLE20 is too large for the BH version because the engine needs to be mounted with the prophub 115mm from the firewall. the DLE is 135mm long...
Clive McInnes of CMC hobbies will have the NGH 17cc shortly. Its shorter then the DLE because its carb is in front al glow style and will fit the Edge. Its not much lighter than the DLE but my BH needs a bit of nose weight even with a OS 91FX on the nose. With a 2stroke glow these ARF's need the battery as far forward as possible. the NGH may be the ticket.
RE: DLE 20cc
To add to Tim's post, the DLE20 really likes a 17" prop and while it can use smaller diameters it really shines with the 17. With the 17" on it it'll make somewhere around 14.5 lbs of thrust. A 16 or 17" prop on the 60-90 size birds tends to be awful close to the ground. Just sayin.
1 Post
RE: DLE 20cc
to add to Jezmo, the bigger prop with create some interesting torque roll effects as you increase throttle so you will probably need a throttle to aileron mix to sort that out. Even with a 91FX my Edge needs a bit of mixing assitance at WOT.
If youave ot bought the ARF yet, get the Seagull .90-1.20 size Edge. The DLE will fit in that and fly it well.
Alternaively wait for the NGH 17 and fit it too the Edge 60-90
MI
RE: DLE 20cc
bernard, both myself and sandy jain put this engine into a seagull edge. http://www.rcuniverse.com/forum/m_98.../anchor/tm.htm#
this is the dle 20 cc forum. you can also check the what are you puttind your dle 20cc in.
Hope this helps. I did replace the landing gear though, because stock gear is kind weak.
