Everyone here will have an opinion on this about engine
PA
What part of the engine would wear out the fastest when under extreme labor,running a gear ratio for all top end,speed pases.I would think it would be the bearings front and rear.What do you all think.Cause the way i have my gearing set up when i want all top end,i'm sure from the off the line start it would be like a real car with a 4 speed starting out in 3rd gear which would labor the engine really hard.The TRX 3.3
OH
RE: Everyone here will have an opinion on this about engine
I was thinking the con-rod. If im not mistaken they are pretty weak and its recommended to change them every 2 gallons of fuel if im not mistaken. But i don't know for sure.
In any normal engine, it would be the piston and sleeve, even under load. But the 3.3 has a weak connecting rod, which may give out long before the piston and sleeve when under a hard load. If you plan on stressing the engine, I would swap the stock conrod for the Davis Diesel conrod.
