Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
OMP 540 Help
Old 08-18-2003, 01:59 PM
funflyer06
Default OMP 540 Help
The instructions say for a fuel tank 4 or 6oz. I don't think thats very big. Could I go bigger and what size? Also where is the best spot to mount my engine without knowing where it balances now. I was going to drill the hole before I cover the fuselage and assemble it. And do you guys think that if i don't trust the strength of the elevator I have should I rebuild? I just don't think its going to hold up in the tight loops.
Thanks.
Old 08-18-2003, 02:16 PM
ChuckAuger
My Feedback: (12)
I have an 8oz on mine, but it's mounted in the wing and I had to make some internal mods to get it in there. 6oz will fly for a good little while, you wouldn't want a lot of fuel hanging off the front.
Just tape your engine on to balance. The engine and battery are about the only 2 things to move to balance it, so I'd get it pretty close with the engine and fine tune with the battery.
The elevator is fine...if it wasn't you'd hear all the "my elevator failed" comments here. I've seen these things do 3D that is almost without equal, and no failure.
Old 08-18-2003, 03:00 PM
ParticleMan
My Feedback: (24)
ParticleMan's Avatar
I have an 8oz in the standard spot on mine. Works fine, and I get plenty of flying time
If you built the elevator like the instructions say it will be fine.
Old 08-19-2003, 11:39 AM
akahoverit
akahoverit's Avatar
6 oz tank on my omp, I think it's plenty big enough.
I've only had 1 problem with my elev, I let someone else fly my plane and when taxi'n back in the tall grass he had full elev pulled and one of the counter balancers caught and broke, the tail skid is bent pretty low so I guess it's kinda my fault. I did a field repair and tossoed it back into hover. Other than that it with handle high speed walls and blenders with no problems.
Old 08-19-2003, 02:52 PM
Scott G
I have a 6 oz in the stock location. My timer is set for eight minutes, but I do a lot of mid to low throttle flying...
scott.
