Brushless motor timing
My Feedback: (27)
I have been looking into what adjusting the timing does to the motor. This is what it seems to be. When you increase the timing you get higher rpms, less torque, more power drawn from the battery and the motor runs less efficiently thus shortening run times. And I assume the opposite is true for descreasing timing? Less rpms, higher torque, less power drawn from the battery and the motor runs more efficiently thus increasing run times? is this right or do I have bad information? I would think that if you are increasing the power drawn from the battery that you would increase rpms AND torque at the same time? Or no?
RE: Brushless motor timing
You're basically right, but the heat increases exponentially too (in the motor and the ESC). Since I'm aware you're doing speed runs, I can simply say for what you're doing, DON'T DO IT!!! lol.
My Feedback: (27)
ORIGINAL: Foxy
