two A123 cells pack in parallel?
Old 09-05-2011, 05:47 PM
RC_MAN
Default two A123 cells pack in parallel?
I plan on powering my next small jet using two A123 2 cell packs and two switches into the receiver. Is this OK? In the o;d days I used two five cell nicads set up this way for years, not sure if it will work if one cell goes bad.
ANY IDEAS?
THANKS
Old 09-05-2011, 06:05 PM
Vincent
My Feedback: (61)
Vincent's Avatar
Default RE: two A123 cells pack in parallel?
No problem...i have done this and both batts drain down equally.
Vin...
Old 09-05-2011, 06:51 PM
Countryboy
My Feedback: (25)
Countryboy's Avatar
I agree with Vincent... no prblem in doing it that way. Same setup here, just through an Orbit Powerjack before the receiver.
Old 09-05-2011, 07:06 PM
GSR
My Feedback: (145)
Have been doing this since 123s came out. Two packs, at two switches two ports. Simple, effective. Use a data logger and turn on switch one, check voltage, turn switch two,then turn off switch one check voltage on switch two. then turn switch one back on and you are in good hands. Scotty
Old 09-05-2011, 08:30 PM
PaulD
My Feedback: (39)
PaulD's Avatar
ORIGINAL: Countryboy
+1
Use the exact same set-up on 2 jets. Works perfectly. Even if one cell in one pack were to instantly fail, the drain rate from the other pack would take a while to bring the other pack down.
PaulD
Old 09-05-2011, 09:07 PM
David Jackson
My Feedback: (15)
+1 more Probably overkill, but I have been using two A123 2s2p packs for the last couple of years in an F-4. No problems.
Old 09-05-2011, 09:36 PM
highhorse
highhorse's Avatar
The only caveat that I am aware of is not unique to 123's. Most switches don't open BOTH the ground and positive wires, and this can cause charging issues when trying to charge both batts on one time.
I use a Batt Share HD to isolate the batts, and to keep one from dragging the other down should a cell fry.
Old 09-06-2011, 01:58 AM
CraigG
My Feedback: (40)
CraigG's Avatar
ORIGINAL: highhorse
You're exactly right Don. I also have been using two 123's on my jets and just make sure I can unplug one or the other for charging, so as to separate the ground wires. Otherwise, these are great batteries with no real negative qualities.
Craig
Old 09-06-2011, 03:56 AM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Also doing parallel A123, but no switches. Using extension to unplug.
Old 09-06-2011, 05:43 AM
phjoker
phjoker's Avatar
ORIGINAL: PaulD
+1
PaulD
+ 2 same set up through the Orbit Powerjack
Old 09-06-2011, 08:55 AM
Meesh
My Feedback: (135)
Meesh's Avatar
Dual A123 2s 2300 packs through a 14 channel Smart-Fly. Works great!
Bob
Old 09-06-2011, 11:35 AM
jetster81
I am using the pro-tronik dual battery input circuit, Ref 78606 , price 11 euros. Its a small unit that you just plug your two x a123 packs into and from there into the receiver it automatically changes from one pack to the other if the voltage drops too low. google a2pro-online.com to find Cheers
