Air Power Electronic dual air gauge, how does it work??
Hello,
I have bought an Air Power Electronic Dual Air Gauge unit (photo below) from Digitech that came with no instruction manual.
Would appreciate help enabling operate unit. There is a servo socket on one side of the unit which supposed to be the power source. Should i place a separate 4.8/6.0V battery or can i simply plug unit with Y connector on a used RX channel?
Thanks in advance for your help.
Regards,
Regards,
My Feedback: (24)
RE: Air Power Electronic dual air gauge, how does it work??
No separate battery needed. Simply use a Y or a spare channel to power the unit with the RX. Current draw is minimal!
Connect one airline to the unit for your gear air storage, one for brakes....
My Feedback: (24)
Dany,
As stated above you can either use a Y-Lead or a spare RX port. Any source of RX battery voltage is adequate. It needs no signal to operate only power from the RX battery.
