FPV Equipment Talk about equipment used for First-Peson View Flying.
Fatshark FPV
Old 09-12-2011, 01:14 PM
joey6589
Default Fatshark FPV
Does any body know about the fatshark fpv like what is the range on 5.8ghz goggles. Also would you recommend this product and were should i buy it. Im just a little hezatant cause im not sure how well they work because i heard the siginal doesent go very far. also if the siginal doesent travel far is ther any way to make it go far. Another thing can you hook the reciver up to a go pro camera.
Old 04-15-2020, 10:06 PM
Kelton_O
There are plenty of range tests for fatshark goggles. The range is really going to be dependent on the antennas you have installed. A patch will give you great distance with a small azimuthal range, whereas an omni will give you good coverage with less range. I'd lookup some rotor riot or UAV futures videos on range testing.
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
