Revo 3.3 clutch problems etc?
Hello everyone! I have a Revo 3.3 #5308. I am embarrassed to say I have not had it out much in the last year. To my surprise I got it out a couple of days ago and it started right up! It ran great that day but today I got it out again and about halfway through my session I noticed in the grass that the truck would rev but it would not go anywhere. I got it back onto the pavement and then it would move but not like it should. Is this the clutch shoes? Any adjustments I can make?
Also I have what looks to be white lithium grease or something that is coming from the side of my starter assembly. Not sure what that is all about. I wiped it off last session and it is there again after today. Maybe these questions are both very obvious but thank you all for your answers and expertise!
Chad
Chad
RE: Revo 3.3 clutch problems etc?
try tightning the slipper clutch (the bolt that holds your spur gear on) if that doesnt work take apart your slipper n clean ecerything good and take some 600 grit sandpaper and roughin g up those 3 pads try that and it should be fine unless something is boken
