Apache 50 Build
RE: Apache 50 Build
Yes man, those trims are amazing, where do you get them? Congrats for the paintjob.
Is that a special or modified apache hull? <span class="hps">not seem a standard one, good work</span>
RE: Apache 50 Build
Thank you. The hull is a standard Aeromarine Apache 50. Custom paint was done by Doug from Overpsprayer.com - he has a thread here that shows his phenomenal work. The trim tabs are from Arrow Shark - the're not cheap but they are friggin sweet.
ORIGINAL: Mario Giordano
RE: Apache 50 Build
Nice boat. Is that radio box from zippkits? If so, are you goin glue the nuts on? I have the same box and I'm trying figure out what type of glue would hold metal to plastic. I may try epoxy and thin cloth???
RE: Apache 50 Build
Aww crap - I was wondering about how the nuts were going to stay in there. I wonder if CA glue would be best.
ORIGINAL: glastronjohn
RE: Apache 50 Build
ORIGINAL: oneboatnut
RE: Apache 50 Build
<div>Progress! I cant take credit for the work so far because I am having a local professional do all the hard stuff for me because I don't want to screw it up :-)</div><div>
</div><div> </div><div></div><div></div>
RE: Apache 50 Build
Boat looks awsome. I have the same hull im doing in electric. I have a tank that looks like yours but doesnt have a mount like that, who makes that gas tank and mount?
RE: Apache 50 Build
Thanks man. The tank setup was custom built and thetray was modified and painted. You can get the tray here http://www.cc-racingengines.com/inde...&Itemid=53
ORIGINAL: timw88
RE: Apache 50 Build
Ever seen those bottle mounts you get for mountain bikes? you can glass one of those in for the tank as theyre only modified drinks bottles .
Mart
http://www.ebay.co.uk/itm/Alloy-Cycl...item4aaf9813d4
OR HOW ABOUT CARBON FIBRE
http://www.ebay.co.uk/itm/2x-Carbon-...item19caefcaa0
Mart
RE: Apache 50 Build
Pretty cool - love the carbon fiber one!
ORIGINAL: martno1fan
Mart
Mart
RE: Apache 50 Build
Made some progress on the radio box. It didnt come with a tray so I had to make one from a piece of plexi glass. Notice the battery meter is mounted under the tray to give a nice clean look. I went with gloss black paint but I plan on making another tray and using a different color.
RE: Apache 50 Build
Speedmaster makes billet trim tabs. http://www.offshoreelectrics.com/pro...ros-billet-tab
Nice looking hull by the way. I added some tabs on my radio box so I can screw into my hull /threaded inserts. radio box is removable I added a piece of thin ribber under the tabs to hold any loose screw from coming out. And I won't loose any screws as I pull my radio box.
RE: Apache 50 Build
Can you post a picture? I am little confused on what you did. Thanks
ORIGINAL: advanced builder
RE: Apache 50 Build
This is what I mean. underneath the tab is a piece of thin rubber sandwiched between the tab and the stringer. They hold the screws from falling out when I remove my box. or placing the box into my hull. And the stringers have threaded inserts added into the new wood piece of stock You need to use resin as glue. I make the tab & wooded stock together as I want my 3 drill holes to line up. The I add a piece of aluminum foil to separate the 2 pieces of wood ,all resin in at once. got it
It's OK to add a lite fiberglass cloth to the tab and box during construction sand out after.
RE: Apache 50 Build
Ok now I got it - thanks for posting. You gave me an idea that I will want to try to get a similar setup.
RE: Apache 50 Build
Getting down to the wire. All that remains is throttle and rudder linkage setup and exhaust tips. Hoping to have her done over the weekend. </p>
Water lines run from rudder
</p>
On/off switch and Killer bee installed
</p>
