thoughts on a possible project
Old 12-19-2011, 05:29 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Default thoughts on a possible project
every year when winter comes, i start wanting 4wd RC's and ones that can tackle the snow.
I already bought a blizzard EV, and a redcat volcano epx pro(will waterproof) and have a scx10 that i have some 2.2 duellies i can put on.
but i also have a part rustler and parts stampede chassis's. And the pics show a direction i am considering going in.
I still have a set of these huge 12mm wheels, 6&1/2 inches tall and 4 inches wide. a pair of trannies...pede chassis ect.
I also have a set of dubro plane skis coming, that i may make a mount for them to put on the front.
The main part i am missing to make this truck run would be a EVX2 system and motors.
So, what do you guys think? Would this be a cool truck if it were built?
ID:	1702307   Click image for larger version
Old 12-20-2011, 05:30 AM
Ducat1
Default RE: thoughts on a possible project
make it a dually with the stampede tires
Old 12-20-2011, 08:18 AM
rchabits
ORIGINAL: nitrosportsandrunner
Why do you want to use fake looking wheels with a real looking body?get some aluminum beadlock rims and crwler tires please.
Old 12-20-2011, 09:57 AM
ORIGINAL: rchabits
try finding any tires with a 12mm hex rim as big as these tires!
plus, i already have them a set of large 12mm hex beadlock rims with massive crawler tires aint cheap.
I dont care for the look of the rims either, but i like trying to build something out of parts i have laying around.
as for the duelly idea, that would be easier. but slapping a pair of stampede tires together adds alot of strain to the stub axle and the driveshafts.
by using a pair of trannies, i can get the same amount of traction as duelies while not adding much stress to the drivetrain.
For now, i think i will just run 1 set of the rear tires...with a mild BL system and mount the skis on the front once they arrive.
I have seen some rusty and pede vids with normal stampede tires and skis and they do pretty well in the snow. and these tires have a fair bit larger foot print than stampede tires.
Old 12-20-2011, 07:49 PM
thehuntingterminator
nice man. that looks like an old 'Pede though
Old 12-21-2011, 07:29 AM
cummins driver
My Feedback: (31)
cummins driver's Avatar
Put some chains on the rear of a stock stampede and go wherever you want. honestly the biggest problem i have with 2wd r/c's is the fronts packing snow up on them. Some ribbed fronts or skis would fix that though.
Old 12-21-2011, 02:38 PM
got one ski mounted. I didnt realize when i bought it that the package only contained 1 ski[&:]
Add a piece of alloy...and bam!
Total cost here is half the kits they sell for the traxxas models....and the skis are larger than on those kits.
ID:	1703245   Click image for larger version
ID:	1703246   Click image for larger version
ID:	1703247   Click image for larger version
Old 12-21-2011, 02:40 PM
cool. i'm diggin those spiked tires.
Old 12-21-2011, 03:09 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
need 3 more, and an out runner with a propeller to be cool
Old 12-21-2011, 04:03 PM
ORIGINAL: SyCo_VeNoM
bypass the outrunner...go VXL on 3s with a 7/10 prop. that should produce some series speed!
Im gonna try the skis with a mild BL system and the spiked tires. if it still gets stuck in the snow to often, then ill go EVX esc and duel trannies.
Old 12-21-2011, 04:40 PM
Ducat1
are you going to make it a posi either way with a single tranny or a dual
Old 12-21-2011, 05:17 PM
ORIGINAL: Ducat1
I had thought about this. posi would help im sure with it not getting stuck. I probly will.
Old 12-21-2011, 07:36 PM
[/quote]
[/quote]
lol, a VXL system on 3s doesn't last long as an ESC... maybe a fireball though...
<br type="_moz" />
Old 12-22-2011, 05:01 AM
ORIGINAL: thehuntingterminator
[/quote]
<br type=''_moz'' />
[/quote]
a few years back i made a fan boat. it was OK with a brushed motor, but then i slapped my vxl on it and ran 3s. it was fast even on my lawn!
My vxl systems have always done fine on 3s.
The stampede has a novatech ESC and 3300kv motor. nothing fancy, but will be plenty of power on 2s for running in the snow.
I have to lock the diffs, build the other ski and make some body mounts. OH, and wait for snow....lol. Should have some in the next week or 2.
Old 12-22-2011, 08:24 AM
Ducat1
if you put jb weld in the diffs it will make it a posi, and i heard that nitro fuel will take it out if you ever want to,
Old 12-22-2011, 04:00 PM
Maj_Overdrive
Maj_Overdrive's Avatar
I'd stay away from a dual rear axle setup if possible as I think that would make it harder to steer even with the ski. Doesn't hurt to try though.
Old 12-27-2011, 11:32 AM
So I got the skis mounted on my stampede, dropped in a BL system and 2s lipo and took it out for a spin.
Not a ton of snow on the ground yet, but I wanted to get a test run to see what improvements it may need.
See for yourself.... and share your thoughts on how to make it better!
[youtube]http://www.youtube.com/watch?v=t7lPLpO87eA[/youtube]
Old 12-27-2011, 12:14 PM
littlemel
I would add some weight up front. Other than that it does ok.
Old 12-27-2011, 12:22 PM
Link119
Link119's Avatar
Put a propped outrunner in the front, and it will destroy what you have. Plus skis all around...
Old 12-27-2011, 12:43 PM
Ducat1
sick build, i would put wieght in the front too, looks like it has traction, btw how did you make the skis. jw
Old 12-27-2011, 12:44 PM
Im thinking i may stretch the chassis 2 inches, and move the battery forward. That and raise the rear suspension.
Old 12-27-2011, 01:23 PM
pics of how i made the ski mount
i drilled a hole for the stub axle to go threw, then made a notch for the allum to go around the steering arm, and another notch so it wouldnt hit the a-arm.
Nothing fancy, but seems to work well.
ID:	1705530   Click image for larger version
ID:	1705531   Click image for larger version
Old 12-27-2011, 04:29 PM
proanti1
proanti1's Avatar
ORIGINAL: Ducat1
A Positrack is a quite complicated thing, and would be pretty hard to cram it all in an RC tranny case.
Old 12-27-2011, 04:56 PM
Ducat1
how is putting jb weld in the differiantal a complicated thing?/?
Old 12-27-2011, 05:21 PM
proanti1
proanti1's Avatar
ORIGINAL: Ducat1
A locked diff/spool is not Positrack. Positrack is a mechanism inside the differential that locks it under load or slippage, but remains unlocked the rest of the time so it can act as a normal differential.
