ZDZ80 Ignition Conversion Question.
I'm converting my ZDZ80 ignition over to an RCexcel unit (the Falkon unit is pooched). I have to use an adaptor to use the smaller NGK CM-6 spark plug. I noticed that the CM-6 does not extend as deeply into the combustion chamber because of the adaptor. Is this a problem? Will I lose horse power? Will i need more than 28* of spark advance because the spark is further away from the piston? Has anyone done this conversion and noticed a difference?
RE: ZDZ80 Ignition Conversion Question.
28 degrees will be fine and you may actually gain a little power due to the ignition change.
You can also change the plug cap over to go to a cap that suits the original plug. They are pretty easy to change. Parts and instructions on how to are available from the RCExcel dealers. (PRC Model is one who is located in Canadia).
ORIGINAL: aussiesteve
this page helps http://www.rcuniverse.com/forum/m_10...m.htm#10725941
so does this one http://www.rcaer.com/userfiles/file/...Plug%20Cap.pdf
http://www.rcuniverse.com/forum/fb.asp?m=10720634
I will switch over the cap since I already a replacement cap from RCexel for a BMR6F plug. My only question now is how do I attach the coiled wire which snaps on to the top of the plug to the ignition lead? The ends of this coiled wire bend 90 degrees and then have a sharp point. Do these sharp points stab into the sides of the ignition wire insulation? All the pictures I've seen on converting caps are for CM-6 plugs.
Yes,
but put the small peace of heat shrink on the wire before you install it and then pull it over the coiled wire(just up to where the coil stops) and shrink it down.
AZ
ORIGINAL: RCdude13
That's what I thought Dirtybird. Thanks. Should I extend the bare ignition wire into the coils of wire? Thanks again for all the advice guys!
AZ
ORIGINAL: RCdude13
