Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
12fg again
Old 01-14-2012, 01:12 PM
jetmech43
My Feedback: (9)
Default 12fg again
ok trying trying to figure out how to mix 2 elevator servos on th vanquish do I have to use the ailevator function to make it work
Old 01-14-2012, 02:14 PM
jetmech43
My Feedback: (9)
Default RE: 12fg again
I cant find the ailevator function in the menu
Old 01-14-2012, 02:28 PM
woodie
woodie's Avatar
Did you use the 12FG setup menu and select 2 elevator servos when you started the model?
Ailevator page 101 of the manual.
Woodie
Old 01-14-2012, 02:29 PM
jgg215
Go to the function menu and assign two adjacent channels to ELEVATOR. Use the separate sub-trims, reverse and ATV menus to make the two sides respond equally. Conditions, trim and dual rates will affect both servos the same.
John
Old 01-14-2012, 03:10 PM
jetmech43
My Feedback: (9)
yes its still not working I have it on the ailevator function but on one servo works
Old 01-14-2012, 03:25 PM
jetmech43
My Feedback: (9)
why cant you just slave 2 channels together and make it work, this is very frustrating
Old 01-14-2012, 03:52 PM
rcpattern
My Feedback: (45)
You can, but there are more efficient ways to do it. One of the problems doing it that way is the built in mixes don't like to work that way (such as elevator-rudder and others) With the newer radios Futaba designed the radios to do most of the setup work for you. That is why it asks you how the plane is setup and than you go under the Function menu you and plug things in as it tells you. How John suggested works great as well, but the initial setup is key on the Futaba radios. They are very easy to use once you learn the thought process.
Arch
Old 01-14-2012, 05:32 PM
jetmech43
My Feedback: (9)
ok thanks Arch and guys think I got it figured out
Old 01-15-2012, 01:50 AM
wagen017
I just upgraded from the 10 to the 12FG. At first this is a problem since it just has a different setup and logic. Also, this is a great radio with a lot of functionality so it does make sense to sit down and read the manual. I have now taken a little 3D biplane and use it as my test bed. To get it flying straight I will need a lot of mixers! Then I can also start to work with conditions etc.
Old 01-15-2012, 01:52 AM
wagen017
to answer the question, after you setup the new model you go to linkage and choose model setup. Here you select 2 ailerons for the wings and ailevator for the tail.
Volkert
Old 01-15-2012, 05:06 AM
jetmech43
My Feedback: (9)
ok thanks have it figured out now
