one way bearing Radikal G20
My Feedback: (12)
WI
Iam looking for a one way bearing on the starter shaft. The manual states CN2263K as the part #. This come up as 'auto hub assembly' and sells for $25 , but all I need is the bearing.
This part is used in other century helis as well and I was wondering is someone can tell me where to get them?
RE: one way bearing Radikal G20
Are you referring to the one-way on the start wand that is attached to your starter, or the one-way in the center of the clutch inside the heli?
ORIGINAL: OliverJacob
This is the one in the clutch.
Mine has well over 100 starts on it and it is going strong. What are you using for a starter?
My Feedback: (12)
WI
I think the starter was the problem, I never got the engine to start, I think it was running too slow.
Now I have build a much powerful gear starter which works flawless on a 50 CC engine.
With a new bearing I should be able to start it.
I should have the tools to change the bearing, I would give it a try before I buy a whole clutch.
BC, CANADA
Unfortunately, due to the press fit, I do not think they sell the bearing on its own.
My Feedback: (110)
PA
you can punch the bearing out with a drift pin without hurting it at all. be careful how you install it back because it can go in backwards and it won;t grab in the right rotation. you'll have to turn it around. check first...........RON
