Help! Sanded a pinhole in my Kovall, gotta start over
Old 02-19-2012, 08:52 AM
Rv7garage
My Feedback: (10)
Default Help! Sanded a pinhole in my Kovall, gotta start over
How do I remove a dope + Koverall finish and start over? Totally demoralizing day...
Old 02-19-2012, 09:12 AM
Chip_Mull
Chip_Mull's Avatar
Default RE: Help! Sanded a pinhole in my Kovall, gotta start over
Why not put a patch on it or finishing tapes? If you are intent on removing the covering, use MEK to soften the dope.
Old 02-19-2012, 09:52 AM
Rv7garage
My Feedback: (10)
'Cause the patch would be visible, and I'm on an insane quest for perfection
Thanks, I'll use the MEK. What's another 10 hours of labor? Hahahahahahahahahahahahahahahahaha.......
Old 02-19-2012, 09:57 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Please use the MEK outside with a mask and gloves.....................
Old 02-19-2012, 10:04 AM
Rv7garage
My Feedback: (10)
ORIGINAL: speedracerntrixie
Most definitely. I have no brain cells to waste!
And then, after the removal process, I get to deal with the dope fumes again! Wheeeeeee! LOL.
Old 02-19-2012, 05:26 PM
kenh3497
kenh3497's Avatar
A patch will crash proof the plane. If the patch is on the bottom (or top for that matter) it becomes an "access panel". Put a matching patch on the opposite side. Don't let ANYBODY tell you otherwise.
Ken
Old 02-20-2012, 09:33 AM
Michaelj2k
Michaelj2k's Avatar
Questions:
1) how large is the pinhole?
2) what did you use to attach the fabric?
3) what is the topcoat? Dope, enamel, urethanes?
4) how did you build up the dope coats? Nitrate, butyrate, color?
I don't believe that you should have to rip off the covering because of a small fault. Can you post a picture?
Old 02-20-2012, 09:36 AM
Chip_Mull
Chip_Mull's Avatar
Also, is the pinhole over a solid surface or open area? Big difference on repair!
Old 02-26-2012, 02:13 AM
cutaway
Unless your finish is clear or translucent, a small silkspan patch will sand/feather out to the point where its virtually unnoticeable.
Old 02-26-2012, 07:18 AM
jaka
Hi!
Why not use automotive 2-part paint instead of dope!?
