DLE 20 choke linkage?
RE: DLE 20 choke linkage?
a simple push-pull rod through the firewall will do, connected to a servo, or a crank instead of a servo. The crank can be operated from the fuselage side.
ORIGINAL: vertical grimmace
So how are you guys configuring your choke on this engine? I am having a hard time getting mine setup in a way that I can get to work well.
1 Post
I run a simple Golden Rod from the linkage, through the firewall and through the side of the fuselage for better mechanical advantage.<div>Its simple, light and reliable.</div>
ORIGINAL: w8ye
All the ones I've seen on cowled models were a simple wire that could be reached from a front air inlet opening of the cowl.
ORIGINAL: TimBle
I use a nyrod (turned/curved 90deg to make some friction) throught the side of the fuse. I put a servo screw in the end to pull on. When it is set right, the screw head is flush with the fuse when the choke is off. Almost looks like a cowl screw, etc. Sometimes a bellcrank is needed.
I really like this idea. The airplane I have this engine installed on is a smallish FW 190. The engine itself gets in the way of running it forward, but I never thought of using a supported cable. This creates more options. Thanks for the ideas guys
ORIGINAL: TimBle
Mine is a 70 in fw 190 and I had no problem running it foward. I didn't even extend the arm. I hooke a ball link to the arm and nyrod and it just clears the engine. A extended arm would make it that more easy.
I made a guide from aluminum and ran the choke control out front. Didn't alter the choke arm, just used a metal clevis with the metal clip to keep it closed. You hardly notice the wiring protruding out the cowling. If you have a radial engine cowl its easier.
ORIGINAL: RBean
RBean whats the deal with your plug ? It looks like you are getting blowby between the ceramic and steel in the pics, could just be residue from oil.
1 Post
ORIGINAL: RBean
Reaching into the prop arc is always a dangerous activity.
<br type="_moz" />
Hello guys, new to DLE and ran in a brand new 20 engine today. Got it to pop with choke closed, opened the choke started and stopped immediately. Did this a few times and decided to leave the choke not fully open. Started beautifully ran up and down, idle good etc. As soon as I opened the choke fully the engine stopped again. Is this just a running in thing, or is it needle setting?
