Hydraulic kit from Hobby King anyone use these
Looking for a hydraulic kit for my F15 and 16 i came across a kit from Hobby King looks like a nice kit. Anyone have experiance in converting gear to hydraulic. And if so what kit is did yall use.
http://www.hobbyking.com/hobbyking/s...dproduct=14054
David
David
My Feedback: (171)
RE: Hydraulic kit from Hobby King anyone use these
hello i bought the setup and tested it, works very good but my cylinders are not up to the pressure that the pump applies, they bleed off very slowly,but the pump and fittings all are leak free,i used sewing machine oil
<span style="font-family: Arial; font-size: small; ">Just out of curiosityDavid.</span><div><font face="Arial" size="2">The system is advertised as a two wheel operation.</font></div><div><font face="Arial" size="2">Will you run an extraT peace for the extra wheel on the F-15?</font></div><div><font face="Arial" size="2">If so will this effect the operation of theunit?</font></div><div><font face="Arial" size="2">I have always wondered about this Kit myself.
Ivan<br type="_moz" /></font></div>
Ivan
Yea i think i would run a t to the nose gear it says its pressure is 10 bar i converted that to 145 psi so i think it would be fine. I wonder how easy it would be to clean if it didnt work.
David
David
I would be mounting the whole set up on a board first, and do all the test on the bench.
This way you fix any problems you mite have with out making a mess in the plane.
Also reminds me of the Eurokit hydraulic system.
http://www.eurokitshop.it/category.php?id_category=219
These haven't been very successful here (euphemism for disastrous!).
Mauri
Mauri
My Feedback: (12)
Yeah, its essentially the UMS kit. Hopefully they fixed the little capacitor problem that was plaquing the UMS unit. I have the UMS unit in my SU-27, its not flight tested but bench tested and works good so far. But if you use the system with a non locking retract then you need some extra check vales to help with locking the cylinders. A little pricey but work well.
My Feedback: (61)
ORIGINAL: dsr71
Vin...
It's a UMS product. I have used several successfully and have just completed a conversion on my 1/7th scale, Twin engined Fei Bao F15E. It knows when to stop when the controller senses the increased electrical load (adjustable), when it reaches the end of the travel.
John
John
Reading the discription on the hobby king page it has a timer on it. I think im going to try them see what happens
David
David
