What do "type a, b, c, d" propeller mean?
I intend to get the RCG 15cc and am looking for propellers for it. I read for run in use 13x6 and after run in use 15x6. But I have no idea what is the difference between types (a, b, c, d) of propellers.
Which type should I get for this engine?
Are the turnigy wood props from HK good?
Any recommendations on props for this engine for sport flying, some aerobatics? I intend to mount this engine on the World Models Super Chipmunk 90R
RE: What do
What brand of prop are you talking about? I don't know of any standard meanings for the letters. The letter designations are up to the individual manufacturer. Could mean anything. Look for a prop in the recommended sizes. Xoar is my favorite for small engines.
RE: What do
I'm referring to the turnigy wood props on HK
http://www.hobbyking.com/hobbycity/s...idCategory=265
And is 15x6 prop too big for this engine, although it is the recommended size? Some people on the HK review for this engine say 14x6 is more suitable
My Feedback: (53)
RE: What do
I would not use HK wood props, they are an unknown. Stick with, Master Airscrew, Zoar,APC, Zinger... they are well known.
Chris923
PS. The letters mean nothing as far as I know.
Chris923
RE: What do
A, B, C are used by Vess. If they cloned the props they probably didn't even bother to change the designation.
http://www.vessaero.com/
Click on tech section
RE: What do
With the Turnigy propellers, the type A,B,C,D, etc refers to the propeller shape when it was made. Such as a wide blade, narrow blade, scimitar shape, and so on.
It may also be the wood used too.
RE: What do
ORIGINAL: pe reivers
Turnigy props are not bad at all. Xoar's are better though.
Xoar and Falcon props are poor power to noise converters but pretty good power to thrust converters, agreed! APC's are too in the smaller sizes (up to 20") except they are so darned heavy. Good to know about turnigy props
RE: What do
I bought a couple Turnigy 16x6 wood props which seem to be well made and nicely finished but don't like the rather thin hub they have, 1/2" thick versus 5/8" for most all the other similar sized leading brands such as Xoar, Hawk, JXF, Menz and Falcon.
Karol
Karol
RE: What do
I have used both Zinger and Master. They are good props, in some engine-plane combinations even excellent if matched well. MA is used a lot in aircombat. They would not be used if they are no good.
ORIGINAL: MTK
Few props convert power to noise as efficiently as Zinger and Master airscrew do. Well, Biela comes to mind too.
RE: What do
I like Xoar and Pro-Zinger wood props, though I needed one ASAP and all I could get locally was a Falcon. I was pleased with that prop and it's been on my plane over a year, now. I balance all my props and I have yet to need to adjust a Xoar. They have all been pre-balanced to my satisfaction.
I hand start my gassers and an APC prop just gives me the whillies; even with a heavy padded leather starting glove. That's what I fly on all my glow engines, though.
RE: What do
I use a magnetic balancer made from computer hard drive magnets. Because the prop shaft is suspended in the magnetic field, it is very sensitive. I rarely have to blade(horizontal) balance a Xoar. Sometimes I do a hub(vertical) balance, but I don't think it is necessary. More like me being obsessive about the balance.
RE: What do
ORIGINAL: SIMCO
I fly a RCGF 15 with a 15X6 evo prop. A 14X8 would be a little deep in pitch but probably alright. SKIP the 13 X8 for break-in . Keep your speed under 6500 rpm with the bigger prop for break-in. Great little engine. Runs all day without a worry.
How about 14x6 as some reviewers at HK has suggested? Is it too small for my intended plane, the WM Super Chipmunk 90R?
Edit: Is it necessary to bench run in or can I just run in a bit on bench and continue run in while flying?
