Gp Waco Bipe 120...how wide?
I'm trying to determine if the GP Waco fuse will fit in my VW Jetta Station Wagon. The specs say 72" length. Problem is I only have 63" from the back of the front seats to the rear of the car. I would need to move it forward between the front seats which are 9" apart. Will the cowl fit through a 9" space. Also, how high does it sit when on the mains and tail wheel? Thanks for the help.
My mistake, misread. Fuse is only 56.5". Still wondering how tall.
My Feedback: (31)
RE: Gp Waco Bipe 120...how wide?
My cowl is about 9 1/2 inches wide; fine if you have padded seats and don't get a prop in your armpit. From the top of the cabane struts to the ground in about 19 1/2 inches, and I am using Skylight 4" wheels inside the pants. My plane goes to the field assembled in the back of my shortbed/covered pickup. If you use the carrying/assembly unit, you will have to add to the height. Can't you put her at an angle?
ORIGINAL: althepal88
My cowl is about 9 1/2 inches wide; fine if you have padded seats and don't get a prop in your armpit. From the top of the cabane struts to the ground in about 19 1/2 inches, and I am using Skylight 4'' wheels inside the pants. My plane goes to the field assembled in the back of my shortbed/covered pickup. If you use the carrying/assembly unit, you will have to add to the height. Can't you put her at an angle?
Friends, I am planning to install on my new GP waco a Saito FG-20 gas engine. Does it has the same power as the 1.2 4 stroke glow engine has??
