Walkera Throttle Hold Problem
I just finished setting up a Dragonfly HM68. It is all original except I installed an orange Rx for use with my Dx6i and I am using a walkera gyro that I purchased separately. The problem I am having is that when I turn throttle hold on than back off the motor starts spooling up even though the throttle is all the way down.It is fine when I first plug the battery in until I turn throttle hold on than back off. I don't know what is causing this and it is pretty dangerous. Anyone come across this and how can I fix it?
RE: Walkera Throttle Hold Problem
should double check your reciever cause walkera heli may not except spectrum transmitter, im assuming you have from what ive been reading you may have to get a walkera/devo tx or change out the receiver. but be honest im new also but its something ive been noticing in my reads.
I am using a dx6i and the receiver in the heli is an orange rx. It is fine to use my setup. Only Spektrum radios can be used with these receivers.
