TL-01 Help/Suggestions
Hey Ive just recently pulled out my TL-01 after being in a box for 3 yrs it still goes just wondering if a 7.4V 5000mAh 30C Li-po will fit if so what esc and motor is recommended and will the receiver need to be upgraded
RE: TL-01 Help/Suggestions
Not easy to tell with the LiPo-pack, but i know you need a stick pack for this car. So the thing you need to do is to look for a stick pack, and take it from there. You can use the same receiver, just hook up the new esc with it and floor it
I came to think of saddle pack here, what about chopping off the "bridge" that surrounds the battery and make some custom mounts on each side? Like a plate bolted to the chassi to place them on?
IL
ORIGINAL: Lars from Norway
I came to think of saddle pack here, what about chopping off the ''bridge'' that surrounds the battery and make some custom mounts on each side? Like a plate bolted to the chassi to place them on?
he he I did some thing like that a while back, sus this it was twin 3s lipo's with a 13t motor... I was luckly to get 5min with out the brushes burning out, but damm it was fast lol
Hey guys thanks for tips nice pics phmaximus and like that setup thought bout a brush less setup though. Can the gears hold up to a high powered motor???
I ave been searchin the net a lil bit it seems the ta-03 ball diff fits the tl-01 does that mean you need 2 1 for the front aswell and also would the ta-06 ball diff fit
yeah bud here is m yother tl01, its brushless on 11.1v
I dident have any lock with the ball diffs. I was using a manta ray one.... it striped out the splines
here is 2 setups the bottom one failed, steer clear ofthe alloy spur
this is what the truck looks like now...
but its having problems again stripping out the splines.
im now swapping it to TT01 style diffs and diff cups
some mean lookin machines there but stupid question with your tl-01s did you ave problems setting the steering trim straight mine wanders after turning at top end know the standard arms are set for toe in is will the turnbuckle set eliminate the wander????
oh ts a road / rally bash the crap out of it i have 1 rolling chassis possibly 2 if i could be bothered to sort through parts and 3 spare chassis complete with gears and a few odds an ends
