CH Ignitions is back
This is a CH Ignition I got for my 1.50 Saito Four cycle engine. It came very well packed and is a very high quality looking CD Ignition. As you can see it came with a bolt-on sensor pick up & very good instructions. Also a timing ring that slips on prop hub, with a set screw. That makes timing very easy to adjust. I cannot wait to run my Saito with this Ignition system. I would do it today, but I am not too use my left arm...I had a P. Maker exchange this AM. I am glad that went well. As soon as I run this engine, I will have video also. The website and phone number is right on the ignition case in photos below. Please keep this thread with input for Ch Ignitions only. Thanks Very Much Capt,n
RE: CH Ignitions is back
If you are going to use glow fuel set your initial timing @ 34*BTDC.
The 28* setting is for gasoline. The slower burn rate of methanol will need more ignition timing for best performance. idle will nt be affeted by the extra 6* advance.
I have set up C&H ignitions W/glowm fuel on FA91S, FA150, FA180, FA180HC/BBC, & FA300TTD emgines. All have picked up considerable RPM W/a more aggressive ignition timing setting.
Thanks for the good tip. My first few runs on the engine will be on glow-type fuel because it has a Glow fuel carb on the engine right now. The second video will be with the engine on gas. I will buy a walbro type carb from Adrian to run same engine on gas. If you know me...I love experimenting....and just love engines ! AV8TOR is the same way... as he does a lot with engines also. Best Regards, Capt,n
I am glad that you are happy with.
I need your guys imput in order to make a better product and be able to support all of you to the best of my abilities and continue Bill's legacy for years to come.
I have the ability of custom curves also and working on a new product that I will not disclose yet.
Adrian
Adrian
Here are couple videos of the engines I have been working on:
[youtube]http://www.youtube.com/watch?v=qWhxMQ4PedQ[/youtube] [youtube]http://www.youtube.com/watch?v=4PiiSsjS2JI[/youtube]
[youtube]http://www.youtube.com/watch?v=M9t5UOq5Eso[/youtube] [youtube]http://www.youtube.com/watch?v=WHT06K6_QyY[/youtube]
[youtube]http://www.youtube.com/watch?v=OX7n8XG0vJs[/youtube] [youtube]http://www.youtube.com/watch?v=Ayw0H2fHiyg[/youtube]
[youtube]http://www.youtube.com/watch?v=qw0oTWr76mQ[/youtube] [youtube]http://www.youtube.com/watch?v=qWmwyTlD0X8[/youtube]
[youtube]http://www.youtube.com/watch?v=jbEXFJjEcDg[/youtube] [youtube]http://www.youtube.com/watch?v=Qeoi88Kt_Rc[/youtube]
Adrian</p>
Thanks Adrian..........I just purchased his CH Ignition to replace a RCexl I damaged with the wrong voltage.........my bad. Adrian had the new CH to my door in 3 days and he personally called and left a message on my phone machine to make sure I got it, and ask if I need his help to call him.....GREAT SERVICE.......I do love the 6.6V CH ignition that matches my 6volt NIMH without using a Regulator one less thing to worry about.........meets my Kiss way of setting up a plane and all 3 of my batts in my 50cc are the same 6volt 5 cell.
Thanks Adrian
Thanks Adrian
Jump Start It will be available again, Iwill make more of those, Ihave all Zenoah parts that are there but Idid not put the price yet.
As far as Ignitions, they are ordered as need. Idoo not keep stock, Since you have the voltage options plus the caps...
So when someone calls or emails I ask the voltage, wire lenght, cap and then Istart to build. They are all custom made.
Iwill work on more engines as time ,money allows me to do so.
Any suggestions are welcome as Iwill try to serve as best I can .
Imy try to get some Rcxel units for people that will want that based on the budget they have.
Iwant to diversify and get as many products in and try to satisfy most needs.
So if you think of something that I should have and be like a one stop shop...let me know and based on the requierments I will try to bring it in.
Ch wnats to be youRC Friend,to help you in the baest way trough Products and Customer service....just me at this time.
It will take a while for people to find out that CH Is back in to the game .and Ihave to THANK BILL for that ,Terry , Liang and most of it you for being a fidel CH Ignition customer.
Thank You
Adrian
Thank You
Adrian
I have a CH Ignition I am installing on a Saito 1.50, 4 cycle. I need too get 2 bolts for the pick-up. Right now I got to fix some problems on the RV as we are now in Florida. Then its back to getting towork onthe Saitoto run it on Ignition. Capt,n
