Carden G-300 Control Throws
RE: Carden G-300 Control Throws
I was running 12 on the elevator and 20 on the ailerons for low. I don't remember the rudder, but I think it was about 25. For 3D it was bevel to bevel. I had the CG pretty far back so you might want a little more elevator to start.
Tracy Hill
Tracy Hill
My Feedback: (69)
AR
I appreciate it. Its almost finished, I had to deploy for 2 months, so it got slowed down. Think its going to be around 33lbs with the QS 150, so should be a blast. Had to modify a couple things, I didnt like the gap between the cowl and fuse, so re-did the cowl to make the gap only about 1/8". Did Gehard mail you the instructions, he said he did. How did the giles balance, I mean when picked up by the leading edge at the tips, was it balance or did the tail droop a little? Thanks, Charles
